Chevy One Wire Alternator
Jonas
Post by Jonas »
Has anyone installed a Chevy One Wire Alternator.
I am going to completely rewire my 66 Short Bed. I have ordered the 21 circuit EZWire Harness. I am thinking about going with a one wire Alternator to simplify things on the charging side.
Questions;
1. Has anyone done this? Any write ups?
2. Does this eliminate the voltage regulator?
3. How much fabrication is involved fro brackets?
4. Any downfalls, besides it's a Chevy part?
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
racerx1699
Post by racerx1699 »
Jonas
Here is the alternator we installed in our racecar ( a 85 mustang with 351) it was very easy with no modication, and the wiring was very easy. It does delete the voltage regulator. I plan on installing a crome version of the same alt. in my 66 when I get to that step. I'm sure there are cheaper versions out ther. I wouldn't hesitate using a one wire alt.
http://www.summitracing.com/parts/PWM-8-47141/
Donnie
2011 F150
32 Ford Coupe
1985 Mustang 10.50's 1/4
1997 F350
If it wasn't on 8 Track it's not worth listning too
Jonas
Post by Jonas »
Thanks,
140amps dammmn.
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
Macon ACE
Post by Macon ACE »
I installed one in my '64 and there was nothing to it really. I had to order a different bracket, though. Mine had one that didn't line up right even for the generator that was on the truck when I got it.
New bracket was about $30 if I recall.
OOPS! I see you have a 390. I have the original 292, so it's a different matter entirely I reckon.
64 Ford F100 Flareside
68 Ford XL Convertible
02 Ford Mustang GT
18 Ford F150 XLT
kstones63
Post by kstones63 »
Most of those generic Chevy 1 wire chrome alternators don't put out very much amperage at idle and low rpm. They are 100 amps but at idle only put out about 35 amps. If you are going to use a/c, electric fans and any other electronics, they won't keep up when the truck idles. If you get in a lot of stop & go traffic with everything on, the battery will drain. Find an alternator from a later model car with injection or one like racerx showed. They put out more amps at idle because of all the crap running.
Ford should make a higher amp alternator that brackets would probably be easier to get.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
