Here are my first attempts, it's pooring rain here so the photos were taken out my dirty front window here in Idaho on this wonderful Mothers Day.
I shoot a Sony A380 DSLR along with a Canon Powershot Point and Shoot however I just started reading and learning the HDR today and from what I've learned you need a DSLR with AEB (Auto Exposure Bracketing) which is a setting that will shoot 3 or more shots in sequence with different exposures, you can use a camera and manually change the exposures and shoot 3 or more shots but I think the difficulty in changing every shot would render it not any fun. Point and shoot don't have exposure settings that I know of so I'd say no Point and Shoot. It will be fun to shoot the old truck once it's sunny enough to go play again and see what I can do with HDR on that. The link in my previous post gives you a good idea of what can be done now I just need to learn all the fun details.oldtrucks wrote:Those are very interesting effects. What camera are you using? Can it be done with a point and shoot digital? I have done a lot of photography in the past with a 35 mm. I'm looking for a minolta digital body so I can use my AF lenses. Like you I can shoot a lot of wildlife and landscape right from our front porch.
Auto bracketing is definitely more convenient, but all you really need is a camera with aperature-priority (Av) mode along with exposure compensation (usually a button marked +/-), which some point-and-shoots do have. Then you can simply set the exposure compensation before each shot to get your 3 to 5 bracketed exposures. For example, -1, 0, +1, or -2, -1, 0, +1, +2, where -1 would be 1 stop underexposed (to retain sky detail), +1 would be 1 stop overexposed (to pull detail out of shadow areas). This typically requires a tripod, but the "align layers" tool in Photoshop usually does a decent job of lining up the separate exposures.Hookedtrout wrote:I shoot a Sony A380 DSLR along with a Canon Powershot Point and Shoot however I just started reading and learning the HDR today and from what I've learned you need a DSLR with AEB (Auto Exposure Bracketing) which is a setting that will shoot 3 or more shots in sequence with different exposures, you can use a camera and manually change the exposures and shoot 3 or more shots but I think the difficulty in changing every shot would render it not any fun. Point and shoot don't have exposure settings that I know of so I'd say no Point and Shoot. It will be fun to shoot the old truck once it's sunny enough to go play again and see what I can do with HDR on that. The link in my previous post gives you a good idea of what can be done now I just need to learn all the fun details.oldtrucks wrote:Those are very interesting effects. What camera are you using? Can it be done with a point and shoot digital? I have done a lot of photography in the past with a 35 mm. I'm looking for a minolta digital body so I can use my AF lenses. Like you I can shoot a lot of wildlife and landscape right from our front porch.
Awesome! Wouldn't it be a blast to take that Ford GT for a quick spin, pun intended!!!ezernut9mm wrote:hey cory, check out this thread if you like hdr and fast fords.
http://www.svtperformance.com/forums/pi ... hread.html
