Need some help with the ignition switch. What terminal on the switch goes to what? We are rewiring the entire truck making most of the harness ourselves. Any help is much appreciated.
I have the wiring diagram for the ol 66, but it is not specific on what each terminal is for.
Wiring
- PFM-64f100
http://fordtruk.com/forums/viewtopic.ph ... ion+switch
See the above thread. It helped me back when I was doing my wiring.
Also checkout this for the headlight switch. Incase you need it. http://fordtruk.com/forums/viewtopic.php?t=19910
- Uncle Skip
- PFM-64f100
Yes that is ground. I do remember that now that you ask.sixty6 wrote:Thanks!
I have a new switch with a 4th terminal, is that a ground?
