Got her home... Now the 'fun' begins...
andgott
Post by andgott »
I picked my truck up from the shop today... I had about 40 miles to go, 20 of which was up and down a mountain with some nice swtichbacks- Which is why I had the brakes checked out before making the drive!!
It went ALMOST flawlessly- The only 'problem' that I had was when the drivers side door came open around a sharp curve- which scared the crap out of my wife who was following me... I just didn't 'slam' the door hard enough :)
Now, I get to sort out the problems, prioritize them, and fix them!!
Peeling clearcoat on the hood... She was repainted in the 80s sometime...
Where the clearcoat is intact, it looks pretty nice-
The only bad rust is in the bed-
The only real dent is thanks to the 16 yr old that owned this truck for a few months prior to me- She made it 44 years without a major problem... The kid wasn't even aloud to leave his own property with the truck, yet he managed to do this-
She needs a new interior- But that's EASY... I've done boats before, so I plan to do this work myself, too...
Pretty clean under the hood, too-
And, Looks pretty good underneath as well-
There are a few things that I have to get done ASAP-
1) Brake/Tail lights don't work
2) Turn Signals Don't work
3) Parking Brake- Handle isn't connected to anything!
4) Speedometer doesn't work
5) Engine Temp gauge doesn't work
6) ALT light lights up...
7) BAD window rattle, and no handles!
8) No inside door handles
9) Bad tires, Ugly mismatched wheels
Other than that, it looks like most of it is cleanup and cosmetic...
I was going to do some things to the engine, like an electronic ignition, etc- But she is running REALLY well right now, so I don't think I'm going to mess with it... I shot a quick video-
http://youtu.be/BvJPHFLHRVM
It should be a fun project- And I'm sure I'm going to have a TON of questions!
-Andrew
Anthony
Post by Anthony »
sounds like you have a good handle on the list... just didn't get no pics :cry: :wink: I'll be waiting on them...
HiBoy63
Ireland
Post by HiBoy63 »
Nice find should turn out to be a nice project. I notice that you are missing a lower gravel pan valance behind the front bumper that goes between bumper and lower grille. Might want to add that to the list of things to do and obtain for the body. Not major just something I notice that is missing.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
andgott
Post by andgott »
LONG day- but I got a lot done!
I'm slowly working out the electrical system- It's a mess- The main problem that I have is that at some point when the steering column was replaced, they used the plug from the new one- But didn't hook everything up! This is the plug- if anyone recognizes it, let me know- It would be VERY helpful to have a wiring diagram so I can tell what wire goes where-
I'm guessing that it's 70's sometime.
I DID get the turn signals working, although the same indicator lamp flashes on the dash no matter which side is flashing.
I think that the stop lights will be working once I've got the new switch in- I need to make a bracket for it tomorrow- But I think I've traced out all the wiring...
I've also got my 'new' factory wheels painted and ready to go- So I'll be getting some new rubber next week, too. Hopefully I'll be able to drive the truck to the tire store :)
-Andrew
sixty6
Post by sixty6 »
Looks like the same connector on the 73 column I have.
I am in the process of wiring up some lights as well. What color wires go to what on your column?
There is almost no such thing as a Slick that has NO issues (I bought a rust free truck this time and have still torn all through it). You have a nice truck there and a good plan - if I failed to say it before;
Welcome to Slick 60s
andgott
Post by andgott »
Thanks for the ID on that connector- I downloaded the wiring diagram for a 74, and it looks the same- That will save some time!
ezernut9mm
Sweden
Post by ezernut9mm »
cool truck and best of luck. sounds like you have a good grip on what to expect.
can't wait to see the progress.
look for your missing parts in the "parts for sale" section. i have found everything i have ever needed with enough patience.
f100jim
Post by f100jim »
Andrew,the 65-66 custom cab dash only had one turn signal indicator light.What color are you going on your wheels?
andgott
Post by andgott »
So- I got out there bright and early, and got the last bits figured out before it got HOT today...
I have a pretty much fully functional electrical system now. Some previous owner had done some interesting things. It was wired so basically there were functioning headlights and tail lights, but nothing else. There were a lot of wires that were just disconnected, clipped, and taped off. Evidently they didn't believe in using connectors to splice wires, everything was twisted together and taped. Luckily, unlike the Jeep I just rewired, they didn't try to bypass the fuse panel!
The stop light switch needs a bracket still, which I should get made today, and I need to pick up a new headlight dimmer switch, too... Mine works, but not reliably. I figure while I've got the dash torn up, I'll replace the headlight switch as well, since the old one doesn't alway seem to work right.
Having the '74 wiring diagram helped a LOT- Many of the wires were the same color, but others were different... Between having that and a 'jumper' to test what wire did what, I was able to straighten it out pretty quickly. I'm going to LABLE everything, too- In case I (or someone else) every has to mess around down there!
The only thing that I can't get to work at the moment is the hazard lights- There is something not wired properly, and they don't work. And, Of course, they aren't on the wiring diagram that I have... Oh well.
I'll look at it this way- I only need those if I break down... And I'm never going to do THAT!!
-Andrew
andgott
Post by andgott »
f100jim wrote:Andrew,the 65-66 custom cab dash only had one turn signal indicator light.What color are you going on your wheels?
I figured that out eventually once I finished tracing the wires out!!
A little more done today- I installed a bracket for the stop light switch-
Everything worked fine, then I took it apart to tighten things, and when I reassembled it, I lost one of the nuts on the switch- It fell into the opening on the top of the steering column, never to be seen again... So, I'll have to get a new one (or a new switch) before it can be finalized... But- It works!
I also replaced the headlight switch and High/low selector switch. Both worked, but were marginal. Now, there is no problem!
The entire electrical system, with the exception of the 4 way flashers- is now 100% functional.... A BIG relief- It was a job I was dreading. I can live without flashers, for sure. Perhaps sometime down the line if I get bored I'll get back in there and play with them.
As for the wheels- I went with red & white-
I think they look pretty good with the hubcaps, too- Which I also just painted-
I'll be going to get some new tires this week... I've got a mix on there now- Some 215 75, some are 235 75... I think that the 235's are the original equipment?
-Andrew
Haus
Post by Haus »
Really like the wheels. Did something similar on my brake light switch, but I like how you drill a second hole to keep the bracket from moving at all. Nice.
All my tools are hammers except screwdrivers, those are chisels.
1966 F-100 2WD
351 Cleveland **no its not a 351M**
C4 trans
3.50 rear end
andgott
Post by andgott »
Thanks. I think that the second bolt is PROBABLY overkill- The bracket was pretty solid even without it- But I figured I'd rather be sure. It IS the brake light, after all!!
I made the bracket in two pieces, so I could adjust all the angles perfectly. It seemed to work out pretty well. I got the switch fully installed and adjusted today, and it works perfectly! I'm happy to say that the truck is now ROAD LEGAL!
Hopefully the insurance will be straightened out soon, and I'll be ready to hit the road :)
-Andrew
cdherman
Post by cdherman »
Haus wrote:Really like the wheels. Did something similar on my brake light switch, but I like how you drill a second hole to keep the bracket from moving at all. Nice.
The second anchor hole is a nice touch. Looks like a sucess. Hope that missing nut does not jamb up the steering someday (doubtful)! :oops:
1683
Planned/considered upgrades:
andgott
Post by andgott »
cdherman wrote:Hope that missing nut does not jamb up the steering someday (doubtful)! :oops:
Yeah, I was a little worried about that, too- though I don't THINK it will...
f100jim
Post by f100jim »
Those wheels look great, Andrew! Sounds like you got that old truck figured out pretty good. Ain't they fun :D
I love how you did the wheels - nice!
andgott
Post by andgott »
Greg D wrote:I love how you did the wheels - nice!
Thanks... I think it will look nice- Not quite stock, but not over the top, either.
She cleaned up pretty well-
The paint/clearcoat that's on there is in bad shape in places... It's going to need a repaint down the line for sure, but until then I wanted to get it decent looking so I can USE it! She's actually got a kind of cool look now, at least in my opinion...
I gave up on getting the hood adjusted any better. There is a pretty big gap in the back, but the hinges are already all the way down. I think that they are just worn out.
The bed was nasty... I got rid of the excess rust, and plan to use a roll in bedliner to cover it for the time being. I need to have some sections of the bed floor replaced, but again, thats down the line.... This should get me by for a while, though.
-Andrew
andgott
Post by andgott »
I got the bed done today- This is a 'quick fix' until I do the sheet metal work that needs to be done- But that's a ways off. In the mean time, I wanted to protect what was left, and also make it look halfway decent-
Looking a LOT Better than when I got it (see first post!)
I also got the parking brake working, too! The cable was disconnected at the firewall- I had to take it all apart to see how it connected- But once I had seen it, it was simple... It SEEMS to be functional now, it won't roll with it engaged- A real plus!
I also got the insurance straightened out- So I'll be venturing down the mountain to get some new tires in the very near future- Then, WATCH OUT!
Anthony
Post by Anthony »
This is looking so sweeet!!!!! I like the wheels and can you push down and back on the hood to get it in place... if so, the hinges are worn..It kinda has that old school look to it.. :thumright: :thumright: had to edit... I meant to ask where are you located???
