AOD trans in my 65
Kid
AOD trans in my 65
Post by Kid »
I have an AOD from a 85 ( ? ) car that I am considering putting in my 65. Will it fit under the floor hump or will I have to replace it with a taler cover..............Kid
cooter
Post by cooter »
i cant see any reason why it wouldnt fit as they are a small tranny but remember to set the tv cable correct or the tranny will be a core in 15 minutes
realisticretiredone
aod in your 65
Post by realisticretiredone »
I put an aod in my 65 and it had a 3 speed in it.Used the Lokar tv cable and it works just greate. The Lokar tv cable came with good instructions on how to adjust.
65ford1
Post by 65ford1 »
WHAT SIZE ENGINE ARE YOU RUNNING?
Kid
Post by Kid »
yes I remember we had to set the cable, Lance had sombody do his on his LTD/Uni. I think he used a Lokar cable also.
I am running a 300 Six in the truck.
realisticretiredone
aod in 65
65ford1, I have a early model 302 and kid if your have a six it's my understanding the aod will bolt right up to your six. james
cooter
Post by cooter »
the aod will bolt to a 6cyl but remember that 302 and 6 cyl have a different balance and require different flexplates
Leeroy
Post by Leeroy »
Can't you use your existing flexplate? Or is the AOD a specific type?
tv cable adjustment seems easy!
http://www.youtube.com/watch?v=6L3hNzxdiYw
dotcentral
Post by dotcentral »
This might be a better video if using a carb and Lokar cable.
http://www.youtube.com/watch?v=jZwsQViZilQ
cdherman
Post by cdherman »
Leeroy wrote:Can't you use your existing flexplate? Or is the AOD a specific type?
I have a free for the shipping used flex plate for a 300 if you want it. The bolts are different though- those I used for my C4 swap. They are shorter than manual as far as I can recall.
I would not recomend an automatic tranny behind a 240, but a 300 should be better.
I nabed a free C4 so I used that -- was scared of the TV honestly...
1683
Planned/considered upgrades:
cooter
Post by cooter »
i ran an aod behind a 300 years ago and was less than impressed with the lack of power in od. make sure you have at least a 373 or 411 gear or it will be a sloutch in overdrive which means it will go in and out of od all the time
fire truck
Post by fire truck »
You need the right tc too
Kid
Post by Kid »
I also have a C-4 that has been rebuilt but it has the small bell and I wil need a flex plate and TC no matter what trans I use, I like the C-4 but thought the AOD might help a little on mileage...........Kid
Jons66F100
Post by Jons66F100 »
The lokar tv cable is super simple to install and adjust...just some patience. Depending on your carb though you may need one of their brackets along with the cable.
1966 F100 5.0 EFI w/AOD
2006 GTO 6.0 6 Spd
I would go AOD Darrell.
If you are unimpressed with the power then upgrade the intake & exhaust - driven properly those 2 mods will improve the mileage even more too along with more power.
I'd want to be around 3:56 or 3:70 for final drive with the OD in one of these trucks. I have one of those ratios in the 64 (don't remember which) - I will likely keep the rear gears I have.
64 Thunderbolt
Post by 64 Thunderbolt »
What all do you have to do to put an AOD behind an older model 302? What all do you need?
64 Thunderbolt Clone (in progress)
Henry J gasser
85 F350 Dually
95 Explorer
64 Thunderbolt wrote:What all do you have to do to put an AOD behind an older model 302? What all do you need?
Depends on how "vintage" the engine, pre 82 have a different balance in the flywheel/flexplate - you will need the right one. I am not 100% sure on the converter bolt patterns - if they would be different. Other than that it would be a normal AOD swap.
This a fairly common swap on early Mustangs (that and T-5s).
Somebody probably has a bolt in Kit that would have a flexplate. You could also (if need be) have your current flexplate drilled for the AOD converter I'd think.
Jons66F100
I have a 370 final gear behind the aod with a stock efi 302. It runs great on the low-end and in overdrive @ 70 mph I'm turning right at 2100 rpm's. It's great for a driver 20mpg on the interstate!
Not to thread jack but greg how did you adapt the clutch with the t-5?
2006 GTO 6.0 6 Spd
I don't have the clutch hooked up yet but will be going hydraulic. Details in my build thread (link in my signature).
