Fuel Float - Im keeping you guys busy
My 66 has a new sending unit in the fuel tank. The PO told me the float has a hole in it and it is full of fuel.
Is the float replacable and if so, where do I get one.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
1998 1100 Aero (Hers)
2001 1100 Aero (Mine)
Wish List:
Win Indy 500
Ask Elvis WTH he has been
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
Re: Fuel Float - Im keeping you guys busy
yes the float itself is replaceable not sure where to get new, i kept some used ones out of other tanks.
possibly patch it with JB weld?
Will the float out of my 76 donor fit?
The donor has a new fuel tank so I was saving that anyway.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
Its just a little brass barrel, if you can make it attach, and it floats, will probably work.
- Alan Mclennan
get a hold of a Plumbers soldering iron and just solder over the hole.
Dennis Carpenter has it.# c0az-9275-f brass float.
Has anyone tried JB Weld?foodstick wrote:possibly patch it with JB weld?
I'm wondering if it would make the float too heavy to read accurately?
I'm not saying I think it would sink - as that would take quite a bit of JB Weld; but would the gauge read ACCURATELY with the float partially submerged more so that it normally would be?
BarnieTrk
- 6166 Junkyard Dog
problem over the years is the float gets bounced around in the tank and thast the cause,, Unlike others I have seen sending units ones with a rubber shield on end so will not puncture a hole in it.........
Kathy
Now Cooper will try his best
i have seen the rubbers on the end of the floats too.
a little bit of solder will not affect the float reading,
You can certainly patch a 50 year old float if you prefer; it's not that hard to access. On the other hand, it's nearly fifty years old, the replacement is available and inexpensive; and probably good for quite a few future years. Replacement parts for ancient vehicles may or may not be readily available in the future, so I would at least consider having one on hand for the future, although other applications will work equally well.
As far as repairing results, if it will float, it'll work; the weight of the repair material will have extremely little effect on accuracy. Obviously the ones with the rubber diaper work just like those without, so the addition of a small amount of sealing material should have no effect.
one trip to the junkyard and you could probably fill a bucket with good used floats.
I've got too many buckets filled with parts alreadyICEMAN6166 wrote:one trip to the junkyard and you could probably fill a bucket with good used floats.
I'm certainly in favor of re-using parts; I've made a pretty good living doing just that, but I'm thinking in this case my laziness would kick in, and I'd buy the part while the words to a certain very accurate James McMurtry song floated through my remaining brain cells.
- Marty in PA
Heck just buy a new one from MAC's or Carpenter - cheap enough- about $5 plus shipping. By the time you mess around trying to fix the existing one or scrounge around for a used one you could have the new in and know it's good. No telling if a used one is any better then what you have now.
Marty
1965 F100 Short Bed w/390 and 4 on the floor.
When half of the people get the idea that they do not have to work because the other half is going to take care of them, and when the other half gets the idea that it does no good to work because somebody else is going to get what they work for, that is the beginning of the end of any nation.
actually quite simple to tell, set it in a cup of water, if it floats its good.Marty in PA wrote: No telling if a used one is any better then what you have now.
I too have buckets of parts.
When I go to teh pick-n-pull I leave with fuses, light bulbs, circuit breakers, wire, fastners, and all the other little odds and ends that we always seem to need.
They usually charge me only $1 or $2 for all that.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
Brian, When the one in my 64 had a hole in it I got the gas out of it and soldered it up and put it in water and it floated. I put it in the tank and it worked for awhile till it let more gas in it and it sank, took me 3 or 4 times of drying it out and soldering it and putting it back in before I got it right.If the hole is on top it will work till the gas sloshes around and gets back in the hole. Just buy a new one from LMC, DC or where ever you can get you one, you will be further ahead.
Will this one work, looks very similiar to me.
Summit is only 20 min away and I need to run up there anyway.
http://www.summitracing.com/parts/omx-1772901
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
looks like it will work, has the groove in the one end of it. Take your old one with you and compare..
AMC used Ford parts so im betting its the right one.
still like said take old one with you.
cant beat $4
cant beat $4
