Transmision tunnel hump cover compatibility
j66b
Post by j66b »
What years/model transmission tunnel cover will fit a 66F100 2WD? Please be specific and accurate. There are none at the local yards and the first time I tried online, I was sent a cover for a 66 F250, and that does not work. The top of the tunnel in my truck is 15in wide, and from the base of the upward curve at the front to the first ridge under the front of the seat is about 21 in. I am installing a warner t-18. There is a three sp column shift now.
Thanks, JB
Re: Transmision tunnel hump cover compatibility
were you sent a 66 f250 4x4 cover (rounded rather than square)
65-79 all 2wd f100-250 are the same cover (4x4 67-79 will also work but has an extra shifter hole)
67-79 f350 also fit
late cover square type
ezernut9mm
Sweden
Post by ezernut9mm »
you need this one:
4 Baja
Post by 4 Baja »
JB, I have this one I no longer need for my '66 2wd F-100 project. M/O for $40.00 shipping included I'll ship it up to you. PM me if you're interested.
Photos are from today.
