64 with memorys
Re: 64 with memorys
Looking good! Lots of progress.
64 Ford F100 Flareside
68 Ford XL Convertible
02 Ford Mustang GT
18 Ford F150 XLT
02 Ford Mustang GT
18 Ford F150 XLT
Re: 64 with memorys
Great start. Will be watching your progress,Tony
Re: 64 with memorys
I don't see any reason that you can't use the head bolt holes to lift the engine out. Make sure that you have enough bolt threads in the hole so you don't pull any threads out of the block.dennyboy wrote:Do you gus just use the head bolt holes to pull these motors out?
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
Re: 64 with memorys
Great progress so far. Very hot here in KY too! Hard to do any work for long periods of time.Tony
Re: 64 with memorys
If you choose to do the '03 up CV suspension swap, the 4.6 mod motor is a bolt-in. Carb manifold adapters are available for the 4.6's, but I would strongly recommend staying with EFI. If OBII, ('96-up), it is coil on plug like the LS's. If you were to find a CV with good drivetrain, grab the computer and all related parts. It will take some wiring changes, but really is simpler than swapping everything to a carbureted system and controller if going automatic. Lots of Mustang five and six speeds out there; hydraulic clutch is a bit of a pain, but certainly do-able.
Do your research! Lots of good info on these forums, but research it thoroughly. People will tell you their favorite is the swap to end all swaps, and can be done for pennies; might want to take that info with a few grains of salt. All swaps have their disadvantages; all builders have their own opinions. Things like correct wheel applications and offsets may not concern some people; others may consider that to be a deal buster. If someone says "this fits", verify, verify, especially when wheels and steering is involved. Some fabricators have been doing conversions for a long time, most are willing to discuss pros and cons, IME.
Good luck,
Good luck,
- 390fastback
Re: 64 with memorys
I'm running a late 90's explorer with disks on mine, seems to work. I'll be swapping a Mark VIII rear as soon as I have an ounce of free time again!!
plus many other's!
plus many other's!
