Build Codes
BigTim
Build Codes
Post by BigTim »
The folks I bought my 65 from removed the door tag. Is there another place on the truck that might have the build codes, other than what I can get from the VIN #. Also where else is the serial number on these trucks other than the door plate.
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
The other place for the VIN# On the 65/66 Trucks is when you take the cab off look on the pass. side of the frame rail on the top side next to the rear cab mount, since we have so many western frames here the are easy to see Good Luck Hunting
12649
66fordtrucknut
Post by 66fordtrucknut »
Tom,Isn't there 1 one the pass. side frame about a foot aft of the core support too?
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
6166 Junkyard Dog
On 61-64 trucks I have seen the serial number by the inner fender on the rh side, I will check closer on these 65/66 frames we have to be sure if there is another one someplace a lot easier to find, I am looking on my western frames since they are clean to see the numbers easy
12649
the vin is stamped into the frame in 2 places on the passenger side, one is about a foot back of the core support, the other behind the front cab mount, under the passengers floor. a good wire brushing will bring them into view.
6166 Junkyard Dog
Charlie & Iceman you both are right :D the frames I ws looking had a lot of greasy build up but finally found the Vin # right behind the support I learned something new :D Thanks
12649
F-100XL
VIN #`S
Post by F-100XL »
That is right, I found both of them on the XL when I was checking the frame when I repainted it.
Bill.
XL
jakdad
Post by jakdad »
Does anyone make repro VIN tags for our trucks? I have seen them for Mustangs. Very good looking tags. I hate having a vehicle without the VIN tag. The frame numbers are O.K. but do not give the other info.
Jim
Mazlem
Re: VIN #`S
Post by Mazlem »
F-100XL wrote:That is right, I found both of them on the XL when I was checking the frame when I repainted it.
Bill.
Welcome aboard Bill!
64Ranger
Post by 64Ranger »
Yes...http://www.datatags.com/
Does an excellant job and very fast.
Doug
Riverside, CA
