223 6cyl Air Conditioning
graybeard
Post by graybeard »
Is any body running AC on a 223? Will the little motor handle it? I suspect mounting a little Sanden one would have to be a home fabricated project. Any thoughts?
If you can't run with the big dogs "STAY UNDER THE PORCH" !!!!!
kstones63
Re: 223 6cyl Air Conditioning
Post by kstones63 »
My truck originally had a 223 in it. My Dad had put an a/c unit in it and it handled it fine. He even pulled a trailer with a 1000 lb. sand car on it along with all of his camping gear and it still did fine. It was a little slow going up the 6% grade going to flagstaff but it still made it.
He found a kit with all of the mounts in it. It used the old York style compressor at that time so if you can find one of those mounts, I am sure that there is a conversion mount adaptor to a Sanden compressor.
You might check with this company.
http://www.ackits.com/
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
banjopicker66
Post by banjopicker66 »
Other companies that may help with A/C kits:
http://www.rainbowproductsonline.com/
http://www.vintageair.com/
http://www.southernrods.com/
Was the 223 used in the '50s trucks? That might get you to an aftermarket kit with the brackets and pulleys if true.
Hope this helps.
62bigwindow
Post by 62bigwindow »
I am glad this topic came up.I just bought a 1956 Ranch Wagon that I had the same question for.
graybeard
Post by graybeard »
I knew someone would have experienced AC in a 223 powered slick. They had, thanks Kieth for your memory. I expected some one had installed one, sure enough. Check out "broke old prospector"s post (with pics) over on Ford Truck Enthusiast.
It's nice to know what your buying for your birthday even if it is a few months away!!!
ezernut9mm
Sweden
Post by ezernut9mm »
you need to get one of those dashpots that up the idle when the compressor kicks on. the 240 in cam's truck had a/c and it was hard to get the carb to idle right with the load of the a/c compressor always changing the idle needs.
Cams truck had the York compressor also....
Those things don't like to run at low RPMs
They get jerky & really can make an idling engine pull down
The 223 doesn't have a lot to spare anyway
I would go with a sanden rotary compressor....
WAY smoother
ezernut9mm
Sweden
i would agree.
