Lowered '65 need tire advice ... and pics
jimwarneke
Post by jimwarneke »
I recently picked up my first Slick, a '65 that I am hopin' to drop about 5" mechanically. I'm not going to bag it at this point, and I'm not looking to do an entire front end swap just yet.
What I am looking for right now is what size tire can I put on the 15" steelies that I have that will look nice and low and tuck inside the fenders when I drop it. I have heard not to go much wider than a 225 on the front without power steering, and I would like to go as wide as I can without having to tub the bed ...
So I guess the question is: What are you guys running on a 15" wheel, and what's it look like? Pics appreciated!
Jim
'65 F100 Longbed Styleside
'66 Galaxie XL 500 Custom build
'67 Ranchero
'94 Mustang GT Coupe
'98 Mustang GT Vert
'04 Mustang GT Vert
'04 F150
and the wife's ...
'11 Dodge Durango
brute66
Re: Lowered '65 need tire advice ... and pics
Post by brute66 »
Was unable to upload pics thanks to my piece of junk LG phone but I just lowered my '66 in the front with DJM Dream Beams and I can tell you that the 235 50 15 tires on 7" wide wheels will not quite clear the fender lip in the event of considerable suspension compression. I've got about 1 1/2" of space between the top of the sidewall to the bottom of the fender (wheel lip). On the back, I haven't yet lowered, but I've got 275 60 15's on an 8" wheel with a substantial offset (deep dish) and it appears that the tire will easily clear the fender lip once lowered to level the truck. If I remember correctly DJM claims about a 2 1/2 to 3 inch drop, I'd say mine was lowered about 2 1/2" although I never measured before vs. after.
LM14
Post by LM14 »
My '66 was lowered with cut springs in front and de-arched springs in rear. 275/60R15 rear on an 8" wheel and 205/75R15 fronts on a 7" wheel. No rubbing anywhere.
jimwarneke
brute66 wrote:My '66 was lowered with cut springs in front and de-arched springs in rear. 275/60R15 rear on an 8" wheel and 205/75R15 fronts on a 7" wheel. No rubbing anywhere.
Thanks for replies, and the pics! That's what I need. I'm trying to find out what look I get with what tire/wheel combo and what lowering method.
Keep 'em coming please!
'67 Ranchero
'98 Mustang GT Vert
'04 Mustang GT Vert
'04 F150
and the wife's ...
'11 Dodge Durango
Red Sledz
Post by Red Sledz »
Lm14 do you have 8 inch or 8.5 on the rear of your truck ? I have the same wheels and had to get 8.5 x15 with -24mm offset and I am worried I may rub now my truck is a 62 wrong bed and rite now has 8 inch steelies with 255 70 15 tires I am gonna run the same rubber but may have to roll the lip under the quarter and maybee pull the quarter out a bit . Would you think. You would have room for .75 wider rubber on your truck? None of this may even matter on account of our beds are different I will post a picture if I am able
Bgbrnbby
Post by Bgbrnbby »
15x7 reversed in the front. 15x7 reversed out back. I'd have to use standard offset wheels up front if Iwanted to lower it more. (Which I do) 235/75r15's all the way around.
You Only Live Once...as far as I know...
