1962 Cab Mounts
Farmageddon
1962 Cab Mounts
Post by Farmageddon »
Hello All
My 62 uni SWB 2WD, is in need of rear cab frame mounts so I can get better stability and not have to worry about the torque box. I understand from reading here that front frame cab mounts from a 1964 will work mounting on the frame and mount to where the existing cab mount holes under the gas tank. My question is 1964's are pretty hard to find, is there any other later years that will work, say 1969 to 1979 etc.?
Thanks Paul :?
unibody madness
Re: 1962 Cab Mounts
Post by unibody madness »
If you can find a set of rear cab mounts to a style side 61-64 they should bolt right up on a unibody.
Hunter's 64
Re: 1962 Cab Mounts
Post by Hunter's 64 »
Re: 1962 Cab Mounts
yep as said any 61-64 rear mounts bolt to holes already in frame
i would definitely call Tom he has lots of frames and parts
LM14
Re: 1962 Cab Mounts
Post by LM14 »
I did this on my project. I'll try to get you some pictures. You need the rear cab mounts off the 61-64 frame, not the fronts.
All the holes exist except the ones thru the floor. That area is already reinforced from the factory. All you are going to need is the rubbers that go between the frame mount and floor pan.
Farmageddon
Re: 1962 Cab Mounts
Looks like I will be calling Tom, thanks guys for the info.
LM14
Re: 1962 Cab Mounts
Post by LM14 »
Here's a few pics of my mount. This is off a '64 bolted to my '62 uni. There is a bolt in the floor pan that is dead center in the mount hole. Didn't drill any holes in the frame, everything was there and matched up fine. This is the right side, left side is identical.
Spark
Farmageddon
Re: 1962 Cab Mounts
Very nice LM, thanks for the photos. Now I can a better idea of what I have to do...pre-she-ate-it.
Paul :D
