Hello all,
The three speed manual trans in Bernadette has been sticking in gear and refusing to shift between first and second. Started with just first gear and only when warmed up. Now she sticks in any gear and at any operating temperature. No grinding or wierd noises but, a few gear oil leaks. Has a floor shift conversion kit and new clutch.
So, after adjusting the Mr.Gasket floor shifter and changing the fluid to no avail, I decided to pull the trans for a thorough inspection. The gears, shift forks, syncros, and bearings look good with the top cover pulled. I think the shifting problem lies in the cheapy after market shift kit and lack of maintenance. I plan to replace this with a quality Hurst shifter. But, while I have the trans out I want to replace all of the seals and bearings. This thing leaks from both ends. I found the correct rebuild kit on drivetrain.com. Problem is I can't find a service or repair manual or any other literature on tearing into this project. Any ideas? Any how-to videos or guides out there? I have access to any tools I may need but would like a guide so I don't waste too much time or do any damage.
Thanks and God Bless!
Justin
3.03 transmission rebuild
lineman1984
Re: 3.03 transmission rebuild
I've used the older chiltons manuals as guidance on working on these. They are pretty straight forward. Sticking in gear is usually not the transmission that is at fault, its usually jumping out of gear as things get too worn. Is your clutch fully disengaging? This would also cause it to 'stick'. For sealing the back, make sure the end of the driveshaft is not grooved at the seal and you might want to replace the rear bushing along with the seal.
i think you should start by seeing if the clutch is out of adjustment
