Steering column swap
oldschool2888
I was unable to get any suggestions on swap so I used and old column I had and made a small jig that located the mounting bracket from a 1966 column to a 1972 column. It located bracket in proper location and rotation. It allowed me to weld column out side truck in a vise much easier to plug weld. Jerry
Re: Steering column swap
It always seems like there is a million ways to do a steering column.. And it usually never goes as easy as you would think. I ended up using the modified column from the 86 donor Crown vic because of the turn signals etc. But I really wish I had a plane old round simple steel housing.
