Dc fuel sending unit wont. Read right inside the tank...
aj64f100390-292
Post by aj64f100390-292 »
Hey, Ive been watching the gauge for a while, Ive bent the arm a time or two thinking it was hitting something but now I know its way off when it reads bone dry and I put 12 gallons or so in and it fills it to the brim..is the float defective? Dousnt sound like it has gas in it...drives me nuts kniwing I spent 50 bucks and didnt get anywhere... reads accurate out of the tank...
Thanks in advance
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now :twisted: soon:pwr asst steering
chris401
Re: Dc fuel sending unit wont. Read right inside the tank...
Post by chris401 »
If your temperature gauge works then the problem is probably not the 12 to 6 volt regulator. If not try running a direct 12 volt wire to the ignition side of the instrument cluster regulator. If it works then trace your power sorce. You can also ground the sender wire out and see if your gas gauge pegs past full.
rwhistles
Post by rwhistles »
I bought one from DC and the arm was way shorter than the original and that could cause what you are experiencing.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
DC Sending units WE DOT SELL For reason they are plastic and 95% of the time do not work
12649
chris401
Post by chris401 »
6166 Junkyard Dog wrote:DC Sending units WE DOT SELL For reason they are plastic and 95% of the time do not work
Mine is a few years old and made of metal. I did not know they sold out to plastic. The arm on the one I have was the same as the one I pulled out.
6166 Junkyard Dog
OH YES, They are selling plastic ones now and presume others are too,, BUT we do not,
12649
