Defroster hose size needed
Anyone know what size the defroster hose is on a '64 f100?
-'61 F100 short box flareside (classic street rod) 223, 4spd
-'62 F100 long box unibody (murdered out) 460, C6
-'66 F100 long box flareside (original) 240, 4spd
-'64 F100 long box styleside (pro-street) 307 GM, 700R4
-'64 F100 long box styleside (daily driver) 223, 3spd
-'65 F100 long box styleside (original) 240, 4spd
-'66 M100 long box styleside (sold) 240, 4spd
-'64 F250 long wrongbox styleside (sold) 292, 4spd
Re: Defroster hose size needed
I had the same issue on my 65, I guess there the same size , I ended up buying 2" first then when that didn't fit , 2 1/2" then attached it to the part of the original hose with duct tape , not the best but it worked and is still holding up. I couldn't find any hoses make for our trucks. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
I bought a hose kit from old air products off of Amazon. it is plastic, but works and fits perfect. (Plastic duct hose, 2-1/2" ID, 6' long #91-53P) I believe it was about $20.
Hope this helps.
Hope this helps.
Semper Fidelis
1961 f100 Unibody BBW
2002 Excursion 7.3 (the bus)
1982 Bronco
2017 F150
2017 Mustang GT/CS
1982 Bronco
2017 F150
2017 Mustang GT/CS
Thanks. I measured 2 1/4", but I thought it must be wrong because I couldn't find anywhere that had that size. Guess I'll have to make the 2 1/2" stuff work..
Update: I've found that rockauto does carry the correct size and ordered some
One time when I took my heater out to clean it up
The vent hoses were very brittle... but complete
They weren't very flexible either
So.....
I took a can of black spray paint
And gave them a good thick coat
Inside and outside ....
Sat them in front of a fan to speed up drying
When they got tacky dry enough to handle
But not completely set up
I nstalled them back up carefully
They were just soft enough to get a tiny bit of paint on my fingers
The next day they were. Hard as a rock solid and strong
3 years later & still perfect
So.....
