I recently put some Dynamat on the floor and installed a replacement floormat from Dennis Carpenter just to see how the mat fit and if the truck was quieter inside. The replacement mat doesn't go all the way to the fuel tank so I found some nice rubber flooring that I'll use to finish the area under the seat.
Probably many uses for this stuff.
http://www.rubbercal.com/tuff-n-lastic- ... oring.html
Rubber Floormat
Re: Rubber Floormat
4'x6' is $42 ...
Less than $2 a square foot
Not bad if its good quality
Re: Rubber Floormat
Seems to be pretty good stuff.
Re: Rubber Floormat
Looks good
Re: Rubber Floormat
Thanks budmercuryv8 wrote:Looks good
