I know I said "SOON", but I had to work on getting it back road worthy after sitting for several years.
First "just to get it running" I started with removing the gas tank emptying it, shining a light through the sending unit hole and with my camera in the filler tube hole, if you can tell what you're looking at, the tank was as clean as NEW. YAY!
Then I reinstalled the tank and put everything new from the tank to the carb. It would crank 1st time and run like a kitten, but as soon as you touch the gas it would shut off....hummm. Then I decided to rebuild the 600 Holley. I expected some trash inside when I opened it up but not this....
Methanol gas...JUNK!
Rebuilt it, runs like a champ. Then... I totaled my Jeep Wrangler on Oct 30th, then I had to start using the 64 as a daily driver sooner than expected.
Time is still one thing I don't have a lot of but I'm here and there doing what I can, when I can.
Next in the close quarters of my shop, I managed to install a newly rebuilt automatic transmission (my old one worked but leaked like nobody's business).
Got that fixed, then had to do some Christmas card shots of my Great Niece
She's a DOLL.
Then one cold Winter day when business was slow, I bought one of these.
and one of these knobs....
Since the threaded shaft on the new lighter was too small for the 61-66 style knob, I removed the brass insert from the 67-72 lighter knob, and the one from the new 61-66 knob. Had to drill out the end of the 61-66 knob a bit, then in the vice I pressed the 67-72 insert into the new 61-66 knob. I also had to insert 2 small washers for spacers onto the shaft before I screwed my 61-66 knob onto the shaft, and it LOOKS and WORKS like a pro. I don't smoke but I had to fill that hole on the dash and now I can recharge my cell phone as well....
Then yesterday was a good warm day for outside. Twenty four years ago I shaved everything off my 64, mirrors, handles, emblems, and all. I ran the truck with 3" peep mirrors hanging from the top edge of me door. That was then, this is now. I can't see out of them very well, so I drilled 2 small holes in my door and put 2 of the 67-72 truck mirrors on each side. That lasted 1 day and I didn't like the looks of them. I have a perfect extra cab (in case I ever wreck my truck) so I measured where the original mirror holes were and applied that to the doors on my truck, so I could cut out the original holes that I filled years ago, installed 2 original style mirrors and I'm much happier with the look, and usage of these...
I know that's not much but now that warmer weather is here I'm hoping to get more done. Until next time, stay safe from this Corona Virus. It's a serious thing.....
