thermostat housing
63 wrongbed
thermostat housing
Post by 63 wrongbed »
I need a thermostat housing for my '62 292, the ones I see available have the connector to the water pump on the side of the thermostat mine has it inline with thermostat. I hope that makes sense, appreciate any help.
thanks James
charliemccraney
Re: thermostat housing
Post by charliemccraney »
The difference is the radiator hose connection. A truck's housing has that at 12 o'clock, viewed from the front.
The water pump bypass nipple is in the same location relative to the thermostat for all Y-Blocks.
63 wrongbed
I guess what I'm asking is will it work on my truck?
charliemccraney
If the radiator hose outlet is at 12 o'clock and it is for a y block, it will work
jamesdfo
Post by jamesdfo »
Found this thread on another channel......
https://www.ford-trucks.com/forums/1484 ... using.html
and these seems to be the solution??
https://www.macsautoparts.com/store/the ... 12-v8.html
63 wrongbed
thanks appreciate the help
charliemccraney
The one pictured is for a car. It will require another hose, probably a universal one.
63 wrongbed
probably need to get different size hoses with this part
FarmMotorSports
Post by FarmMotorSports »
Is the correct one from ford-y-block.com to expensive? NLA? Or did IMiss something in this thread?
61 F250 Unibody
& 4WD
jamesdfo
Post by jamesdfo »
Well, I'm not a Y block guy, so not up on who has the goods.....but FarmMotorSports is spot on on this one!
Car on left,$65.00. Truck on Right, $59.00
http://ford-y-block.com/
http://ford-y-block.com/accessories.htm
http://ford-y-block.com/price_sheet.htm
63 wrongbed
thanks gonna give them a call
63 wrongbed
I bought the housing from John Mummert fits perfect
FarmMotorSports
Glad to help...
61 F250 Unibody
& 4WD
