Finally. Heat!
Doc Pepper
Finally. Heat!
Post by Doc Pepper »
After fifteen years, I finally have heat. The engine began to overheat and I started to smell something in the cab, as well as seeing some wet stains under the plenum. So I picked up a replacement heater core at Auto Zone. The new core was extremely light (made of aluminum), and I was worried about its ruggedness and reliability, but I was determined to replace the 55 yo core. When I installed the new core (it went right in), I added some padding around it to ensure that all air had to go through the core. And it worked. Now I wouldn't try to melt steel with the BTU output, but, with the passenger window down (Mandatory when you have an 80 pound dog), I actually had a warm cab with the blower on low.
Over the years I tested the core with air, I tried different hose placements and configurations, and I even went to a 180* thermostat, but nothing worked. I guess, sometimes, you just have to buy a new core.
Re: Finally. Heat!
good to hear from you Doc !
i have taken several non-functioning heaters apart
a good cleaning and the hoses hooked up correctly
have made them blow good heat
main problem around here (kansas) is mice love to
pack them full of seat cushion material for nest !
Doc Pepper
Re: Finally. Heat!
Well, would you believe that during my heater core test ride (50 miles), the alternator failed. And when I changed it out the water pump failed (water all over the place, in fact the shepherd got a full bath). And of course on the coldest day of the year. And the auto store did not have the right lower radiator hose, so I had to put the old one back. Then she overheated right off the bat even though I had filled the radiator to the top. But when I refilled the radiator with another gallon or so, everything worked. I guess I'll try it around town for a few hundred miles, but it looks like it is working and I do have good heat.
Re: Finally. Heat!
Heat is a great thing!
It always amazes me how the snowball effect works. Experience it quite frequently too. Sometimes I wonder if I'd just fix whatever when it fails instead of putting it off, if I'd avoid rebuilding the whole vehicle later when I finally fix the first problem. Might be old vehicle karma
Doc Pepper
Re: Finally. Heat!
Well, its been a month. I still have heat and I still have a full radiator. Almost forgot the horrible sense that my truck is no longer capable of holding water. Now if I could only get two doors.
