Fuel gauge ??
Fuel gauge ??
ok so if i fill up my tank it only goes up to 3/4 full on the gauge. Not that big of a deal but i would like to fix it. what part should i replace? thx for the help.
1965 F100 short bed, daily driver for 42yrs 1 million+ miles
OLYELLER,
Pull the two wires off the sender on the tank and touch them together. If your guage still only goes to 3/4 the issue is the guage. If the guage, with the two wires connected, goes to full the issue is your sender. The senders can be pulled apart and cleaned up fairly easy. I can't remember where, here or fordification, but there is a "how to" article on the tank senders.
Jason
Beer will change the world.
I don't know how but it will.
- crewzinforabrewzin
Here is the link guys, http://www.fordification.com/fuel-sending-units.htm
Just touching the wires together will point you in the right area but some troubleshooting may be needed when you get there.
If you do try to clean the resistor wires as mentioned in the article I may also add as long as you are removing the cover remove the rod and float also and clean up the the edges of the cover and housing by the tabs and also the float "pivot rod" ,pivot rod holes, and area where the springs on the rod contact the housing. A good connection between the rod and the "housing" is needed. Just be carefull not to break off the "sweeper".
Jason
- 6166 Junkyard Dog
try replacing the little voltage regulator on the backside of the inst. cluster
Kathy
Now Cooper will try his best
If it doesn't go to full when you short the wires at the tank. What Tom is saying is that if the problem is the fuel guage, it may be the voltage regulator behind the dash and not the guage itself....6166 Junkyard Dog wrote:try replacing the little voltage regulator on the backside of the inst. cluster
cdherman wrote:If it doesn't go to full when you short the wires at the tank. What Tom is saying is that if the problem is the fuel guage, it may be the voltage regulator behind the dash and not the guage itself....6166 Junkyard Dog wrote:try replacing the little voltage regulator on the backside of the inst. cluster
if this was the case your other gauges would be off as well.
