CV front end alignment
To any one who's worked on one of these (or any other ifs swap)
I'm looking for tips and tricks to make sure I've got lower control arms aligned correctly. I have about 1" of play side to side before I am pushing hard on the bushing.
"Let the Devil have his Chevy, thank God Jesus loves His Fords." -Angry Johnny and the Killbillies 'Creepy Pete'
fordman125
I'm planning on using the CV reat axle with the disks on it, I just need to locae another Police package vic to salvage it from... I got back to the yard too late on the last ond. I may use the stock CV bosster or just an aftermarket street-rod type. 03+ vic had 3.55 posi rear, I think that is right where I'd like to be. (also the extra width on the exle will help it match the front. (my current stock rear would need 3" spacers on either side to line up the outside of the wheels.)
GDG, mine is allmost in, and hopefully this weekend I'll get the rear bushing mounts made (Did you box the inside of the frame to mount for the inner hole?) I was debating having the bushing rotated in the housing to keep it indexed corectly.
I've got a few more bits to fab up, before it all goes back together. I should be mocking up the engine mounts nextweek. (I think a Fox Body Mustang oil pan is going to be about perfect (any of you mustang guys have some advice on a low profile rear dump oil pan)
I'll post some pics soon.
You looking for a larger capacity pan? Otherwise a stock one should be fine.JFCDeuce wrote: I should be mocking up the engine mounts nextweek. (I think a Fox Body Mustang oil pan is going to be about perfect (any of you mustang guys have some advice on a low profile rear dump oil pan)
You looking for a larger capacity pan? Otherwise a stock one should be fine.[/quote]
I am concerned because the CV crossmember sits basically flush with the bottom on the frame rails. The large front sump looks like it will colide with the steering rack, although I have not gotten too far into the measurments yet, not looed at a 302 mounted in this truck from the bottom.
As you may have seen in your research as well, tire clearance is the biggest issue with drop. the federwells and tires are very close, any additional drop and there would be no ability to turn.The Big M wrote:Just out of curiousity, how much drop are you guys achieving by swapping in the CV crossmember?
EDIT: Never mind, I did a search and 4"-6" seems to be the answer. 8)
So, when dimantling the radius arm bushings, I noticed that only the driver side had a alignment washer to center the rear pin of the arm in the eccentric hole... (I looked all over for the right side one thinking it had rolled away.) I went to my dealership today to see if they could get one, and it turns out that it is only used on the lest side arm, the right one is just bolted up tightly in the eccentic hole
Does anyone have any idea why this might be? I can only think it might have to do with diver weight or something of that nature.
Also to those who have dome the swap, did you fond the left and right arm like to be aligned a little differently and need a bit of persuasion to be symetrical? Just wondering before I start welding on these bracket mounts.
I think that the slotted bushing is an production assembly aid, probably to compensate for frame tolerances. It seems that I remember the crossmember mounting holes on one side were elongated also. Just center things up and tighten them down, thats what I did. That's how they came off of my donor frame.
Doug
Doug
fordman125
so you guys build shims for the brackets on the trailing arms to keep the mounts at the same angle that they are what ever that is slightly tilted in i would like to know the reasoning behind that carcrafter22 over at FTE made his flat with his frame I am about to do my first mock up soon so i would like to know what to do with those
