What size booster are you running?
Southern64
Post by Southern64 »
I have a '64 about to get a 302. I just put discs on the front, keeping the drums in the rear. Wondering what size booster I should run ? Any have this booster:
http://cgi.ebay.com/ebaymotors/9-CHROME ... 0084658450
or have an opinion about it? Thanks
Southern64
No love for brakes? I know other people on here have them, haha....
Kid
Post by Kid »
I plan on using one from a 66 on my 65 and 64. They are a little smaller and will ifit well with the mustang dual master Cyl I plan on using.............Kid
UNIFAN
Post by UNIFAN »
If you are going to buy new MB marketing sells a bolt on kit with a 7" dual booster and master cylinder with proportiong valve, brackets, and pedal rod. You can also change the booster size if you like.
dwbr
Post by dwbr »
if you are having issues with space and are running power steering a hydroboost is an option, you just have to use a high pressure power steering pump, that has been my biggest issue, will probably switch over to a saginaw style pump on mine
________
Park (Bridgeview)
truckerdaddy66
Post by truckerdaddy66 »
I'm using a 1982 chevy assy. Had to modifie rod lenght and bracket almost a bolt up deal.Also used spliter block ,using 2001 camaro calipers and rotors.I bought m/c, booster,and block &lines from local salvage yard real cheap! $25.00 I'm using a 2001 camaro cross member,with no problems yet.
Truckerdaddy66 ,New Caney ,TX.
just waiting on the huricane
