GhettoTech-Lowering
GhettoTech-Lowering
Anybody know how to lower a slick without spending much? I dont want to slam it, just drop it down a little. I figure that shackles in the back(junkyard) and some junkyard springs with a different profile in the front. Of course,I dont know what I'm talking about, thats why I ask.
I was hoping to spend less than $200 (Besides $ for poly bushings, I'm not counting that) I'm not too up with prices anymore, this is my first project in years.
(just sold my honda today to get money for my truck, it was awesome, the guy drove it home with no brakes, just the emergency which I would have done too but I'm nuts. Of course I did not recommend it- he was so psyched about the car he said he was driving it to work tomorow LOL!!!)
___________________________________six two
well in that line of thought, i lower my 4x4s by adding firewood in the bed and a plow on the front.ABA wrote:Throw some cinder blocks in the back and put some low profile tires on some 13in rims on the front![]()
That should lower it some
now to be serious, the cheapest way to do a straight axle truck is to put the axles on top of the springs, for the twin i front i will let someone who has done one speak.
now to be serious, the cheapest way to do a straight axle truck is to put the axles on top of the springs, for the twin i front i will let someone who has done one speak.[/quote]
I was thinking of doing this exact thing. But I thought there would be interference with the centerlink or other suspension parts. Have you successfully done this mod ?
SOMETHING WICKED...
THIS WAY COMES !!
THIS WAY COMES !!
IN MY OPINION, SAVE UP AND GO WITH THE MUSTANG II. IT COSTS ALOT MORE ,BUT LOOK AT WHAT YOU GET. I RESEARCHED EVERY AVENUE AND FINALLY BIT THE BULLET. I COULD NOT BE HAPPIER WITH IT. RIDES LIKE A DREAM. ALSO YOU HAVE MANY MORE OPTIONS WHEN IT COMES TO HEIGTH. YOU CAN USE DROP SPINDLES, CUT YOUR SPRINGS, RAISE OR LOWER THE CROSSMEMBER IN YOUR RAILS DEPENDING ON HOW YOU WANT IT TO SIT. NOT TO MENTION YOU CAN MOVE THE CENTERLINE FORWARD TO CENTER UP THE WHEEL IN THE FENDERWELL. JUST MY TWO CENTS.
the low low rider
Cinderblocks, firewood, come on seriously guys I meant low budget- I use dirt instead, that stuff sosts money, its just that all the sand bloiwing around in my cab is starting to get to me. If I get rich I'm gonna pour a couple of inches of that fancy cee-ment in that there truck to lower it.
But....
I do like the idea of putting the axle on the "inside" of the springs, like boss9 I want to know are there many issues with the steering? Like will the tie rod come into contact with anything? I am not sure if I will do this anyways, it looks like the truck could be too low for me then. I know, I'm getting picky now, this is on a budget, I know that you usually get what you pay for.
_________________________________six-two
But....
mustang 2
jva118
Yeah, I like your idea, I just want too keep it a little more "stock" than that, no good reason, I just like the way it looks. (and I'm cheap)
On the other hand I used to know a guy who put a camaro front end/PS/PB, chevy 350 in his 54 GMC and it did drive very nicely, it was cool in the aspect that it was very "useable" as it was his daily driver.
If flipping the axle is to low I think you might just want to have your spring eyes reversed and re-arc them.
Fliping the axle (if it is posible,but I will get to that) would get you about 2-3"
the reasion I say if it is posible, is because I thought I would do that but there is some axle to frame clearance issues as well as stearing.
The stearing can be fixed with a spacer between the stearing rod and the spindle.
If you re-arc the springs and have the eyes reverced you can probably get 2" then if you do longer shackles then you could get anothe 1-2" without the clearance ishues.
The clearance ishues and between the axle and the frame inboard of the spring.
I may be wrong on my drop numbers but these are the things you should look at and concider.
my
my
"flipping" the axle (I call it spring under because you don't actually flip the axle) nets you the thickness of the axle PLUS the thickness of the spring pack. I'm too lazy to go measure, but that's what you'd get. I was too worried about messing with the steering and went with a dropped axle instead. There are no doubt issues with that as well, but I felt more comfortable with them than the spring under axle.
My Slick is rustier than your Slick!
THIS IS A PIC OF MY TRUCK WITH A MUSTANG II WITH DROPPED SPINDLES AND A LOOP CUT IN THE FRONT. ALL I NEED TO DO TO RAISE IT UP 3 INCHES IS ANOTHER SET OF SPINDLES AND SPRINGS. THE GOOD THING IS I CAN SELL THE OTHER SPINDLES ON EBAY. OR KEEP THEM AND CHANGE THE LOOK OF THE TRUCK WHEN I GET AN URGE. THE GOOD THIS IS AS LOW AS I AM I STILL HAVE FULL SUSPENSION TRAVEL. AND AGAIN IT RIDES LIKE A CADILLAC.
[albumimg]967[/albumimg]
[albumimg]965[/albumimg]
lowering
Comet- Thanks for the reply, I might just flip the axle, dont know yet, I'll probably think about it over the winter as I live at 7000 feet and dont have a garage. (cold)
jva118- Damn that truck looks good!
MadMaxetc- How much would it cost to re-arc the springs and flip the eye over, it sounds like a good idea. THANKS!
Well you have to see if your current springs are any good.six-two wrote:How much would it cost to re-arc the springs and flip the eye over,
You would have to find a shop that could do it and ask. It depends on a lot of things. I would look for an outfit that does the Big trucks like F-700 types. They would do springs and would know.
Spring Company
Check out www.eatonsprings.com They make stock Slick springs and can make them in lower versions as well. Thier prices are fair. When I decide to update my leafs I'm going with them.
