GregD finally built his panel truck
Photographic evidence has surfaced!
- Johnny Canuck
I started on it the day after JC was here. Been slaving on it for months here. You guys really don't like it?
I say shorter too
- Johnny Canuck
- Alan Mclennan
On the shorter version!,
- FORDMANLCRACKEL
Yep short does it for me.
Lonnie
Lonnie
I suppose I will have to go out and buy another Uni then?
BigTim wrote:I think it would look good with the long wheel base if a foot was taken out behind the axle.
yes, then it would not look so much like the extended econolines i had.
I dunno, I think it would look good either way.
This one looks to be about the same length as Greg's truck & other than it being a Chebby, it looks purty good from here.
Although, panels do look good shorter too, either in 2-wheel drive form...
...or in 4-wheel form.
Or I guess if you're really needing something different you could always do this.
One similarity I'm noticing with the trucks above, is the raised area in the roof where the rear meets the front. I don't know if it was done for added support or what, but it looks kinda cool.
I still like the shortened version, especially with the lwb wheel arch proportioning. The longer version would look alot better if it had less rake to it. It would also need the characteristic Slick roof extension to finish the roof's lines, that would make more difference than you might think in th proportion of the whole look. Maybe the triangular 1/4 window from an econoline to fill some of the panel section too, would likely make a more balanced look too. I may have to play around with this some more stating with my paint job sketch blanks (I drew one and made copies to try different schemes). Has giving me more of a cohesive picture to work from though, Thanks Tim!
