headlight relays found
jeffw
Post by jeffw »
just got the latest from LMC truck and seen a couple of things I want,,
they are the headlight relays. 30.00 bucks for a set ,,now hopefully they come with instuctions, anybody here get any of these?? well they are on my list of must haves..also there is a lighted front bumper that I thought was kinda cool, however the don't make em for uni's with the three bolt hook up, they have the fog lights built right in.. give me an idea how to make my own, just plasma two 4 inch round hole grind her smooth, hook up a mounting plate on the inside and voila!!!! oh yeah they also have trim rings that would compliment the hubcaps..
FORDMANLCRACKEL
Post by FORDMANLCRACKEL »
Fordman
Post by Fordman »
the way i read it . it is 29.95 per side. when it says quanity it says 1. unless they are hooked together.
jkimbrel65
Post by jkimbrel65 »
I have that kit. 1 kit both lights. works great. well worth the money
I tried being normal once...
jeffw
h
Post by jeffw »
did the instructions come with it Mike?
jkimbrel65
Yeah sorta Gotta read chinenglish.Pretty straight foward plug there harness into one headlight pigtail and plug there 2 to the headlights and one hot to the battery and your done
ezernut9mm
Sweden
Post by ezernut9mm »
http://www.fordification.com/forum/view ... &sk=t&sd=a
a guy over at the fordification site makes these. they are better quality than the lmc pieces.
GDG
Post by GDG »
All the late model cars and trucks in the junk yards have nice relay centers, anywhere from 3 to 6 relays mounted on the wheel house. They make for a very clean installation, and they are cheap!!!
Doug
i get the original bosch relays with the pigtails from my auto parts guy and make my own harnesses.
Lowell
Post by Lowell »
I just tied in to the hi and low beam wires on the left inner fender just behind the radiator support with two driving light relays and ran a hot wire to the solenoid with a 40 amp breaker. My old harness was in decent shape so didnt replace it. Havent had any more blinky lights,and it cost less than ten bucks !
Slick Fan
Post by Slick Fan »
ezernut9mm wrote:http://www.fordification.com/forum/view ... &sk=t&sd=a
Looks like progress has slowed, now that his girlfriend moved in. :lol:
:laughing:
dirtbike
Post by dirtbike »
FORDMANLCRACKEL wrote:These are a bit cheaper
http://www.allelectronics.com/make-a-st ... Y/-/1.html
and the instructions
http://fordtruk.com/index41.html
Lonnie
I tried this the other night (without the beer unfortunately) and could not get it working...
Will try it out again sometime... with beer! LOL!
-= FORD F100 1965 =-
jwh f-100
Post by jwh f-100 »
I have thought about making up some of these kits. Would I be stepping on anyone's toes by doing it???????
I even have a thought by making these in a way that are still very install freindly but would fit the look of a classic very nice..
Jason
Beer will change the world.
I don't know how but it will.
i would not do it without making an entire new harness with 14awg wire to the lights and plug ins for the relay and inline 20A blade fuses.
also very nice to have it so hi/low beams are on at the same time(i added a extra switch to control this.)
i brought my entire old harness inside when i made the new one , also did the rear lights at the same time, everything soldered with plug ins at the stock places.
Uncle Skip
Post by Uncle Skip »
I got my relays with the correct plugs from the junk yard for a buck.
Both of them.
I cut the plug wiring as long as I possibly can, but even if you cut them short just be sure to leave enough so you don't have to splice the wires right at the plug.
I'm going to look for some more because I'm planning to relay several other systems including my a/c.
You might have to get one each from different cars, but if they're from the same year and brand car, getting them from the junk yard is a pretty cheap solution to a semi-expensive problem.
Just my dos centavos worth..... :wink:
Tio Skip
Uncle Skip
Also, I'm running my original wires from the light switch to the relays to operate the relay.
I will also use 14 gauge wire like Ice from the battery source to each relay with an inline fuse on each one, and from the relay to the lights- 20 amps is sufficient ..... and no fuse required on the light bulb side of the circuit.
BTW, again, at the junk yard, I found some inline blade type fuse holders that have cap seals on them.
Amazing what you can find on late model wrecks if you look close.
U@ss
Truckfarmer2
Post by Truckfarmer2 »
I wired mine from scratch and it sounds like what Skip did EXCEPT mine uses a circuit breaker instead of fuses. I don't want no lights at all at highway speeds.
i thought about replacing the fuses with 20A circuit breakers too. its a good idea.
foghorn
Post by foghorn »
Well as little as i know about wireing im going to buy another of 390nut's harness's over on fordification. I do know how good those work as i had one on my 1970 f-100. He has also made improvements to his design. I do know that pauls work is of high quaility.
Foggy 8)
