Rear disc`s
Rear disc`s
Been thinking about converting the rear brakes to disc`s, as drums are hard to find round here!, found a conversion that will put 12"x 3/4 late model Mustang disc`s with ( I`m sorry!) corvette calipers, a bolt on setup> What are your thoughts on rear disc brakes?
Rear discs are pretty much a complete waste on most of our trucks. For a truck that doesn't haul anything the stock rear brakes are almost overkill.
You towing a trailer - go for it.
My 62 has Impala calipers & 94 F 150 rotors so don't let it bug you.
DV65CustomCab
Post by DV65CustomCab »
Causes problems coming up with a handbrake too. I'm with Greg on this...has no purpose other than adding bling and bragging rights for the local cruise night. Any drum parts you need are only a message post away.
Stop The Longbed Hate! :)
Now: '93 F150 Lightning
dwbr
Post by dwbr »
a few years ago they started putting disc on new trucks, ive seen they went back to drums on most models, if the factory stopped there has to be some reason
________
free drupal themes
grw
Post by grw »
I did disc swaps on my olf FJ40 & Samurai, (a plus while wheeling through alot of water & mud) not alot of breaking differance (if any). Other than that, they are easier to maintain. But how often do you need to replace your rear shoes/pads?
Gary =)
fmartin_gila
Post by fmartin_gila »
I agree wholeheartedly with Greg. Also keep in mind that if you don't have to look at the Calipers all the time, you don't have to be so ashamed.
Fred
Michelle
Post by Michelle »
I do have rear disc on my 56, also use a proportioning valve and have them balanced very well. I have had no problems what so ever in 20,000 + miles. I increased my peddle ratio at the same time and I will say the truck will stop on a dime. As for rear E brakes I have them too. I took the E brake cables and housings off of a 79 Lincoln MK V, fabbed some brackets and used them on the Lincoln Versailles rear. I installed a parking brake foot lever from a 73 to 79 Ford pick up. I am not saying the rest of you guys are wrong by any means but it works for me.
Michelle
1961 slickwilly
Post by 1961 slickwilly »
i've been thinking about doing mine to with rear discbut since i dont think my 292 will be getting up to nascar speeds i dont think i'll need them
Phil
Post by Phil »
A common swap for the Torino guys is the Crown Vic rears but the Truck axle ends seem to be different than the car 9"
PFM-64f100
Post by PFM-64f100 »
I plan on upgrading my 64 and the crew cab to rear disc. One problem I have found is the rear rotors and the 5X5.5 bolt pattern. I can find 5x4.5 all day long so if I have my axles changed or redrilled it will work. I want to keep my 5X5.5 pattern so I went looking and this is what I have found so far.
Use a mid 90's explorer 4x4 front rotor (I have the part number and year at home). The reason for the 4x4 rotor is no center hub. Then use the corvette calipers with ebrake. The problem/fun part is the flange (the thing the studs mount to on the axle) is about a 1/8 of an inch to big so the axle's will have to be machined down just a hair for this rotor to fit. That is the one part I haven't done yet. After that get the weld on braket for the cal and put it on there. This is the weld on bracket $10 http://www.aa-mfg.com/pdshop/shop/item.aspx?itemid=7
Another option is to get the chev rotors that are 6X5.5 and have then redrilled. There will be 2 holes that are "egged" but if your ok with that then they will just go right on (from what I have read). You can also a front caliper mounts from a 89 1/2-ton 4x4 Chevy Suburban and modify it to fit. Double check that because the article I was reading was for a Dana but I swear I've read it for a 9" 5x5.5.. This is the link to the artilce I'm talking about. http://www.greatlakes4x4.com/showthread.php?t=31308
Here's another link I have for a 9" convertion using the chevy parts.
http://www.pirate4x4.com/forum/showthread.php?t=121194
Another thing I will be doing to both of the trucks is a hyro boster setup. Using this link as a reference. http://www.ncspecialties.com/autobody/hydro/index.htm I just need to get to the bone yard and find on a hydro booster.
The main two reasons I will be converting to rear disc is because of:
1. Towing (I want to know I will have enough breaks to stop when towing a heavy load). The one thing I hate is that feeling I won't stop been there done that not fun.
2. Disc are stupid simple to change out pads plus I will save my fingers and eyes (along with any other body part) from those springs... Drums have there place and do the job.
Oh yea on other thing to think about when looking for rear rotors is thickness. the calipers are only good for rotors about 1" thick. I have found serveral rotors that would work but there to thick.
Also If you willing to run 17in tires check out the mid 90's (I think) rotors from a dodge pickup. They have the 5X5.5 pattern and will clear the flange but will not fit a 15in rim. You might have to do something with the braket also as the rotors have a bigger diameter that the others. Just a thought.
And for you Dana 60 people like me here is this link for rear convertion. http://ramchargercentral.com/index.php? ... show;id=66
Hope this helps Alan...
36truck
Post by 36truck »
Here's some brake options for you.
http://www.9inchfactory.com/brakes.shtml
Tom Williams
charliemccraney
Post by charliemccraney »
Several companies offer rear discs in the 5 x 5.5 pattern for 9". ECI and The Streetrod Manufacturing Co. come to mind. The only thing I do not like about the 5.5 pattern is it will not be easy to get a replacement rear disc if it's needed in the middle of nowhere.
Some Jeeps have the 5.5" pattern. I looked at that idea a while back. The pilot in those rotors is larger than that on the axle. This room can be taken up with a tight fitting spacer. Then you have a rotor you can buy off the shelf. I believe the other dimensions were ok to fit the axle flange. I made a drawing of the rotor but I have no idea where it is.
Lawrenceville, Ga
1961 F100 Unibody
Thanks for the replies Guys and Gal!, the brakes will be going on to Beryl and she is going tobe my work truck, with moderate loads and some times pulling a trailer!, I`ll check out the links given and see my options!, some of these people want to retire on one good idea !, Thanks again,, Alan,
TxSlick66
I sell rear disc brake kits, and I would not do it on mine..
Post by TxSlick66 »
The cars are alot lighter and have brakes designed for their weight range. A slick weighs about the same as a new Mustang but with a LOAD is alot heavier. Who knows how those brakes would act with a big load coming down a hill, with someone's family sitting in their minivan at the stop light at the bottom?
I could fix you up with a 2005-2009 Mustang disc brake kit that would fit the rear using FORD parts, but you would have to redrill the rotors for 5 on 5.5" pattern (no big deal). I just do not think you would see any improvement in braking that you would really notice. Ebrake hookup is a pain but not really that hard. I just see no reason to "go there" on these old trucks...
If you really just HAVE TO DO IT, get a rear from a late model TRUCK that has TRUCK BRAKES on it...
TxSlick66
aka MustangSteve
Money you ENJOY wasting is NOT wasted money...
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
we have run in the past 75-79 Mark V complete rears shave all that rear suspension off, don't cut off the brackets that your brake cables go through to reattach to, then weld your saddles back on , one thing is you might want to change center section since geared real high like 2:23 to 2:40's and redrill axles to your wheel specs
12649
6166 Junkyard Dog
:oops: Alam might not be too many Lincolns down your way :( :( :( :lol: :lol: :lol:
12649
6166 Junkyard Dog
:oops: sorry spelt you name wrong not Alam but Alan face it just a bad key board operator :(
12649
bluebolt
Econoline disc brakes
Post by bluebolt »
You could use Econoline van disc brakes. They had rear discs available starting around 2002 with the 5 1/2" pattern. You would have to use 16" wheels though I believe. They use a small drum brake for the emergency brake so it's easy to hook up.
Fairlanes down here had rear disc`s with a drum brake in the disc housing, I also noticed that the bigger jap suv`s have rear disc`s as well, gunna check that out today at my local Pull and How Much did you say!. just a question!, If drums are better than disc`s how come you dont see sports drum brake up grades?, I know the disc`s suck at being hand brakes tho!
No worries Toon! :lol:
