Working on a custom exterior bed light
Brian Taylor
Post by Brian Taylor »
I want a bed light but just can not take the norm. I am going to take one of the side emblems, FORD 100 Twin I Beam, and clean or replace the lens and add body for depth to put in the bulbs and mountit above the rear glass with an interior map light on the other side to help conceal wires and give the cab some light too.
I was going to keep the emblems on the side and remove the Twin I Beam and write in RATTLE CAN for the name of the truck but I like the cleaner look of no trim.
I will photograph the process and add it to the galllery. I sure hope it works out as good as it did in my head. (I need to start drinking again)
1966 Ford F-100 LWB 300
Cool idea - if you have a space problem with the fender emblem a 63-64 hood emblem should be a little smaller up & down.
Brian Taylor
You know I had this idea but I have not measured the available space.
I'll be right back..........................
Okay it will fit, the FORD will be in the heavy curve section from the roof but it will fit nicely.
Falcon Interceptor
Post by Falcon Interceptor »
Would look cool if you could french it in, then you would just be using the face of it and not have to worry about adding the depth to the emblem.
You shouldn't have to cut out the letters at the top, just make a similar hole and use a plate on the back of the emblem, (with cutouts for the light to shine through) that fills in the rest of the hole.
It would seem this would all be above the headliner? If it is you wouldn't even have to hide the inside of the box you added, and yes you could hang an interior light off it.
Just my thoughts
Image 64 shorty, 300 big block, T-19, 3.89
