hot engine cranking
- bobenhotep
hot engine cranking
why would an engine crank smoothly when cold but have the starter drag once the engine is warmed up? the engine is a 223...
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
- bobenhotep
figures ground...my main cable going to the starter is questionable, so that might be a culprit also
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
Ford blue blood
Another common failure that causes the "hot drag" issue is the bushing in the nose of the starter. Take it out and disassemble the starter, tap out the bushing and turn it around. The center shaft pennetrates just about half way into the nose so turning the bushing around gives you a new bushing.
Many great Fords,
Nice trick, it reminds me of the mid 60s being a kid with no budget to speak of back when repair work did not mean going to the flaps for a "rebuilt" replacement but fixing what you had with what you had.Ford blue blood wrote:Another common failure that causes the "hot drag" issue is the bushing in the nose of the starter. Take it out and disassemble the starter, tap out the bushing and turn it around. The center shaft pennetrates just about half way into the nose so turning the bushing around gives you a new bushing.
Also check the timing.......if it advanced too much , that problem can happen
Thunderboy
Electrical resistance increases with temperature. Start with battery cable connections at both ends of each cable.
Something an auto instructor friend of mine (Jim Custeau at Cuyamaca College) tells all his students, and I find it very helpful:
"Most electrical problems are resistive in nature, and the problems usually occur at connections."
Drew
66 F250 Frame swap, EFI 408W, ZF 5-speed swap (still!) in progress
63 Falcon Futura EFI 331W, T5, but not much progress... Slicks First!!!
i have seen a lot of thin cables on trucks which can be a problem. cranking creates heat in them, and voltage drops.
also just because a cable looks good on the outside does not mean its good on the inside, it could have hard spots which indicate corrosion and look like a green penny.
all of the early 61-64 starters had a ground from a starter bolt to the frame.
i agree very strongly with the instructors statement.
- bobenhotep
the pos cable looks like it was a welding cable put on there so the truck could swim across the ocean and do bay of pigs, so ill change it and work from there. it has a hole in it and is a nice statue of liberty color. the end of the cable is full of motor oil...
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
