Headers for 390 FE ???
betfm
Post by betfm »
I just put the 390 FE engine in my 1961 F250 unibody. The headers I had will not work as they end right at the crossmember, so the tubes need to go down farther to go under the crossmember.
I am using the single front motormount and the 2 mounts on either side of the bellhousing like a 292 is mounted.
Anybody know what kind of headers will fit?
Do the F100 and F250 in 61 have the same crossmember?
Also, there are headers listed by Hooker and Hedman for 65 and up f100's but I have no idea if the rear crossmember is the same :dontknow: or if they will work on an F250.
This is a 2 wheel drive truck.
"I just need a bigger hammer"
Ed
1961 F250 Unibody long bed ,(Under construction)
rick heisler
headers for 390
Post by rick heisler »
will those fit a 429 might be able to help u buy new headers
Re: Headers for 390 FE ???
betfm wrote:I just put the 390 FE engine in my 1961 F250 unibody. The headers I had will not work as they end right at the crossmember, so the tubes need to go down farther to go under the crossmember.
not sure what you can do finding headers for a 61 with 390, maybe someone else has the answer;
as to frames
61-64 2wd f100/f250 are the same
65/66 2wd f100/f250 are the same but have different frame than 61-64
so what works on f100 will work on f250
for Rick H 390 and 429 do not interchange
betfm
Post by betfm »
rick,
The headers will not fit a 429--wish they did
Ed
Uncle Skip
Post by Uncle Skip »
You cut out the old cross member that mounted to the old style bell housing, right?
That means you have a Trans-adapt crossmember.
If so, use any FE exhaust that fits a passenger car.
Sanderson makes a really nice set of block huggers with real 3/8" flanges that will not leak.
FYI
I have original 427 cast iron shortys and they fit like a champ.
Works on all the early model Slicks.
'61-64 only.
'65-66 is another animal.
U@ss
betfm
Post by betfm »
No, I did not change the rear crossmember, still has the old style bellhousing and stock crossmember.
Ed
64 f100
Post by 64 f100 »
I think Sanderson makes some nice headers to fit 53 to 56 , should fit these trucks.
Uncle Skip
Rich is right.... wait, isn't that Rush is right.... well anyway, tell them what you're doing and ask for the "block hugger" headers.
U@ss
betfm
Post by betfm »
Thanks Rich & Uncle Skip,
I checked the Sanderson site and they do make headers for 53 up F100's with 390/427 FE's. Kinda pricey, but I'm getting old and can't take it with me. I will give them a call.
Thanks Iceman for the frame info--that helps.
Ed
Ed
64 f100
Post by 64 f100 »
I am not going to leave it for my children. If they get anything they are going to have to earn it by selling off all my stuff.
Rich :twisted:
Hawkrod
Post by Hawkrod »
65-76 4X4 headers for 352/360/390 work fine in a 61-64 two wheel drive if you are using the 65/6 F350/4X4 style mounting system with the bellhousing and timing cover. Hawkrod
betfm
Post by betfm »
Hawkrod,
That is what I was thinking about trying 4X4 headers as they look longer in vender pictures. I wanted long tube headers. I don't know what the 65/6 F350 mounting looks like, but mine is mounted with the front timing cover and on either side of the bellhousing. There is plenty of room on both sides.
Thanks, Ed
Ed
Hawkrod
Post by Hawkrod »
betfm wrote:Hawkrod,
Thanks, Ed
F350 used timing cover and bellhousing mounts. Probably what you are using. Hawkrod
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
I agree with Hawkrod on fitting , I have use the same type headers for my 56 since 1974 all I order the header for any of the 65-76 FE Motors then when get them in cut a slot between each manifold port for a better sealing fit... personally we have gotten away from headers puts too much heat on starter and after you have changed a few starters with headers on FE 'S you will get the idea
12649
6166 Junkyard Dog wrote:personally we have gotten away from headers puts too much heat on starter and after you have changed a few starters with headers on FE 'S you will get the idea
exactly why i did not use them on my towtruck and the set i have are hanging on the wall in my storage van.
betfm
Post by betfm »
betfm wrote:
Hawkrod,
Thanks, Ed
Actually, I modified the stock 63 390 timing cover for the front mount. i will have to see how it works out.
Ed
betfm
Post by betfm »
6166 Junkyard Dog wrote:I agree with Hawkrod on fitting , when get them in cut a slot between each manifold port for a better sealing fit... personally we have gotten away from headers puts too much heat on starter and after you have changed a few starters with headers on FE 'S you will get the idea
Do you cut a slot completely thru the header flange between each tube for each port?.
What about header wrap or heat shield around the starter? This is NOT going to be a daily driver :lol:
Ed
