original radio tech data
Gnarls Hectic
Post by Gnarls Hectic »
Anyone have the manual/schematic for the original radio I could get a scan 0f? I need to know how the washer stack up goes so the tuner works.
FORD Models: 12BT/12BU (C1TF-18805/C1UF-18805)
AM Car Radio Photofact.
Any help is appreciated.
Dale Radford (Gnarls Hectic)
Myrtle Creek Or
my classics
1966 F250 352 V8
1961 GMC K1000 305 V6
1977 Yamahammer XT500 Thumper.
Ford Gallery
http://tinyurl.com/ygq6mbp
GMC Gallery
http://tinyurl.com/yg2n58s
gumshoe
Post by gumshoe »
I don't have this photofact, but I'V seen it on ebay, should have bought it. check justradios.com
Bill: shasta lake ca. 1966 F100
there is a section on radios in the shop manual.
i have taken apart and removed several radios, the washer stack is not always the same. if you did not keep count when you took it apart the trial and error method is fairly simple. also even with the correct stack, overtightening of the nuts can cause the shaft to bind or become misaligned.
