NEED HELP WITH A NON SLICK A 1971 F250
1958FRIDGE
Post by 1958FRIDGE »
THE OTHER DAY MY BROTHERS WHEEL CAME OFF HIS 71 F250 IM GUESSING HIS WHEEL BEARINGS WERE THE CAUSE. SO NOW HIS SPINDLE IS NO GOOD WHAT I NEED TO KNOW IS IF THE F100 FRONT I BEAM IS THE SAME AS THE F250 I BEAM. I HAVE CALLED MY LOCAL AUTO PARTS STORE AND THE F100 AND F250 WHEEL BEARINGS ARE THE SAME SO MAYBE THE BEAMS ARE THE SAME?
1958 FRIDGE
1965 COMET
1965 FALCON
1958FRIDGE
I GUESS I SHOULD ALSO ADD THAT THE I BEAM FROM 65 TO 69 IS DIFFERENT THAN THE 71 AND LATER
1958 FRIDGE
1965 COMET
1965 FALCON
MadMaxetc
Post by MadMaxetc »
If you replace the spindle, i-beam, radius arm as a set you will be fine.
There is a good writeup on most of the diferances at Fordification.com
They deal with 67-72 Fords.
My Build Thread
1958FRIDGE
THANK YOU
1958 FRIDGE
1965 COMET
1965 FALCON
