Disc brake swap question
62bigwindow
Post by 62bigwindow »
I know that at least one of our members has used the CPP disc brake kit for 61-64 straight axle trucks.My question is why do the calipers have to be ground on?Is it for wheel clearance when using the stock steelies or something else.I am ready to order mine and want them powdercoated but if they need to be clearanced, powdercoat will be money wasted.
Post by Gritsngumbo »
As i understand it, it's for clearance unrelated to the innie wheel fitment. Why not grind them and then powder coat them?
dave r
Post by dave r »
Mine had to be ground to clear the caliper mounting brackets.
Dave
jwcnj45
Post by jwcnj45 »
As previous post states it is for bracket clearance. I got my disc kit from Speedway Motors. It was less than the other brand and I believe the brackets were made by CPP,as well as the instructions. If you haven't bought a kit yet you might check it out and save a few bucks.
Uncle Skip
Post by Uncle Skip »
And.................. if you're trying to save a few bucks, get the brackets and buy the rest of the parts locally.
Greg D. posted the parts list in hints and tricks.
http://www.fordtruk.com/forums/viewtopic.php?t=2647
U@ss
With todays gas prices, it could very well be cheaper to buy a kit and not have to drive around all over town looking for parts. I bought the CPP kit on e-bay for $350 including shipping (which I thought was a great deal at the time). Speedway now has the kit for $279 plus about $50 shipping (YMMV)
Don't let grinding the caliper intimidate you.
60 grit flap wheel on a 4 1/2" angle grinder takes about 10 minutes a piece.
noley99
Post by noley99 »
I had to grind mine for steering clearance.
Like Greg said, no big deal grinding the calipers. I used my bench grinder then smoothed them out with the flap wheel.
Family First!
62bigwindow
I am not too worried about the grinding as much as spending the extra money on powdercoating then having to grind it off.I remember reading Greg's post but could'nt recall why he grinded the calipers.Thanks for the help.
sully5
Post by sully5 »
I used the CPP kit but sourced the parts locally at SUBSTANTIAL savings. Got most everything from one parts store, so gasoline usage was minimal.
If thou bleedest not, thou workest not. - Hezekiah 2:12
I take it you are planning on buying the calipers already powder coated? As I said before, why not buy them plain, then have them powder coated locally after you grind them?
Powder coating isn't expensive.
62bigwindow
That is what i am probably going to do now.I just did'nt want to order them already powdercoated and then have to modify the calipers and grind off paint.
