Hard to crank on Mondays
- Blackwaterforge
For the past two Monday mornings my truck has been hard to crank.
I don't drive it on the weekends so it sits from Friday evening til Monday morning.
It acts like it is not getting fuel.
Then it will crank and runs fine with no other issues.
66 Ford F-250 with 300 6 cyl.
Could me mechanical fuel pump be going out.
How much fuel pressure should I have?
Thank You!
Thank You!
DirtyHerri
- Alan Mclennan
DirtyHerri wrote:I am hard to crank up on Mondays, but my truck starts up fine. I doubt there is a fix for that.
Anyway, have you changed the fuel filter recently?
when you say ''Hard to crank'' ... do you mean it turns over slower than normal ?
if so , i would say you have a small drain on the battery... and it isnt fully charged
the carb empty of fuel wouldnt make it ''Hard to crank''.... you would just have to crank it over longer
my
my
Unfortunately that is physically imposible. Just for starters, liquid can only seek its own level which means the lines would always have fuel in them. Most often if is fuel vaporization from heat soak but if anybody tells you it drained back they don't know what they are talking about. Hawkrodloosrp wrote:I have the same problem, new fuel line and pump, even pulled the sending unit out of the tank to look at the pick up, all good. The fuel drains from the carb back to the tank.
- Blackwaterforge
Thanks guys
Truck has to turn over longer before it cranks.
Once it cranks it runs fine.
Is it possible that the needle valve in the carburetor is not seating fully and fuel is drained from the carb and has to be filled by the fuel pump before it will crank?
Fuel filter is clean. Tank is clean.
It runs fine after it cranks.
It acts like it is getting no fuel.
Like Hawkrod said. It can't drain back.
I would bet that the float is adjusted wrong so the bowl is not getting full of fuel. Then when it sits, it evaporates off and you habe to crank it to fill the bowl up so it will run.
Also if the float nedle is not seating it will let the fuel in the line level out with your tank.
- Uncle Skip
- Blackwaterforge
Thank you for all your replies!
I put a kit in the carburator (Carter YF) yesterday.
Everything looked ok but I did adjust the float a little.
The fuel pressure is steady at five pounds.
How long should it take for pressure to leak down in the fuel system?
Pressure dropped to two pounds in thirty minuets and one pound in an hour.
Overnight it dropped to zero.
Is that normal?
Thank You!
Is that normal?
Thank You!
Pressure can leak down as soon as the engine is shut off. The fact that yours does not means you have a tight needle and seat as well as good check valves in the fuel pump. The reality is I am amazed you can hold pressure that long after shutdown. HawkrodBlackwaterforge wrote:Thank you for all your replies!
Is that normal?
Thank You!
- Blackwaterforge
- Blackwaterforge
