Who out there has rebuilt a 352 with good horsepower ?
rcb1020
Post by rcb1020 »
Will do Chris ! I'm gathering info now and then gathering parts after the holidays are over. Maybe put a few parts on my Christmas list
1966 Ford F100 SWB
1966 Ford F100 Camper 4 x 4
2009 Ford F150 4x4
Effie
Post by Effie »
I didn't read everything... I'm exhausted and fixin to go back to bed.
Number one..... An engine it an air pump. The more efficiently you move the air, the more efficiently the engine will perform. So many people have the misconception that more fuel equals more power. NO... more fuel only means you're gonna run rich and screw up the stoichiometric air/fuel ratio of 14.7:1. Also the efficiency of the engine breathing also means you'll increase your fuel mileage.
Secondly - Its not horsepower, its torque that matters. So many people lose sight of that. Torque is the measure of the work, horsepower is just a measurement of work over time. Torque is what puts you back in the seat and gets everything moving. That's why a torque converter is called just that, it multiplies the torque.
Here's a good article to actually understand the horsepower and torque before you start building an engine -
Car Craft - HP vs Torque
I don't mean to sound like a know-it-all pain in the ass, I just think its important for people to understand the fundamentals of an engine when they're wanting to make power.
~/\/\elissa~
Image '66 F100 -- Little Black
Image '78 Bronco -- Brutus
stronger66ratfink
Post by stronger66ratfink »
well!!
my original 352 with 96,000 miles was rebuilt by USA racing engines of Houston, bored 30 over and stroked plus loads of changes
she should be runing about 325 plus horse power now and it's as strong as ever, and never had a problem and it's coming up to almost 8 years
I get about 10 to 11 and I can't see any problems.
long live the 352
chris401
Post by chris401 »
What crank did you use to stroke it? My original 352 will clean up at .020. Would like to keep 352 crank. Ive also been researching the 390 vs 410 crank to gather at what point would I be over acheving on CI and start loosing economy. It would be nice to have some pistons made for either crank. Im using my C4 G heads, they have a good low to midrange design. After the OD install 18mpg+ is my goal.
