65 F100 Body Drop
SLAUGHTERHAUS FAB
65 F100 Body Drop
Post by SLAUGHTERHAUS FAB »
Has anyone body dropped a 65 F100? I am looking for some general info on what and where to cut and how to do the bed. I want to lower the truck but the kits available don't go low enough to give the stance I want and really don't want to get into a load of money just to lower it. How much have guys been paying for the newer crown vic front ends and can you bag them fairly easy? Might have to bite the bullet for a mustang 2 but am wondering how long parts will remain available for them.
I'm also looking into cutting the long bed and frame down to a short bed if anyone has good info about that.
1965 F100 Built 302, Stock C6, Rusty and in need of TLC
If you have an LKQ (Pick a Part) in your area which offers the Thanksgiving holiday weekend 1/2 price sales, you should be able to buy a CV front for around 150.00, if available.
Be sure to bring a cordless 1/2 impact and an able-bodied friend. Certainly keep all the hardware.
ezernut9mm
Sweden
Post by ezernut9mm »
i couldn't give away a short bed twin i frame. it just left on a trailer last weekend. i think he is going to make a trailer out of it.
hoq far out in kansas are you? i might be able to get back.
*ryno*
Post by *ryno* »
what are you trying to achieve?
laying rockers or just a lower stance. a "body drop" or channel is a shit load of work. a properly built 61-63 i know will lay rockers without cutting the floor, never messed with a 65, but i doubt there much different as far as cab mount heights and such go.
The Big M
Post by The Big M »
Have you seen UNIFAN's build thread? It may help answer some of your questions: http://fordtruk.com/forums/viewtopic.ph ... sc&start=0
It appears his truck is able to drop right into the weeds with minimal floor modifications, if any. Just a front and rear Z in the frame, along with a raised bed floor.
ford6t5
Netherlands
Post by ford6t5 »
throw in a jaguar front suspension and you have the desired stance that you are looking for. do a search in hints and tricks and see matt's f100.
i'm going for it. i throw out my dropped i beams and get me a jag front and rear on airride if static is not low enough.
see ya
twan
deflaytedwayz
Post by deflaytedwayz »
Just go out to your truck and look and see if the frame hangs below the rocker. If not than you'll lay body once you notch the rear and figure out which front suspension you want to use. Then bag it or put hydros on it and you're set. You could keep it twin I-beam if you so chose.
ford6t5
Netherlands
Post by ford6t5 »
your crossmember will hit the ground before the body does.
see ya
twan
Uncle Skip
Post by Uncle Skip »
Joey chopped/ butchered a perfectly good cab years ago by cutting the floor out and never finished it.
Not saying it can't be done, just that you really should consider what the finished results will look like and will it be worth all that trouble.
Slicks are a lot different that the old F-1's with a flat floor because of the cab mounts and supports.
My dos centavos worth.
Tio Skip
UNIFAN
Post by UNIFAN »
Do yourself a favor and do a 61-64 truck. Way fewer issues to deal with.
ford6t5
Netherlands
Post by ford6t5 »
if you want to lay rocker install a jag ifs and z the chassis in the front make a c notch in the back and your done. you don't have to cut the cab and bed.
maybe it is easyer to do this.
see ya
twan
dragginwagon
Post by dragginwagon »
when i did my 65 few years ago i clipped it with a camaro subframe and then put 2x4 in side the frame rails uinder the cab and choped off the bottom 2-3 inches ( cant remember exactly how much it was. only have to do bout 3 feet of the frame on each side. not very tough at all.... once you do that it will lay flat like a 61-64 frame
lil crude but it was one of my 1st
shoulda cut a bit more off the bottom, like i said my 1st go at this type of build.
