my 4x4 simply known as ..............Eventually............
Re: my 4x4 simply known as ..............Eventually.........
I beleive I will do it the "carpenter" way Kenny... measure twice cut once.... run, check, bleed twice, down hill once... and stop..
Well, I got just a little more done... I have the truck cleaned out and ready for the "roll" down to the bottom of the hill... I bought and ran my fuel lines today... tank to carb... I ran metal lines most of the way and used rubber to just do the connections... just a couple pics...
and my one of a kind coil cover...
Well, I had to move my build and re-do it in order to get all the pics back up guys. If you had posted on the original thread, I am sorry to say that I didn't move the responses but just my build... from here on out this will be where I am keeping my build on Eventually, The '66 4x4 that will "eventually" get done...
thanks for all the support and hopefully I will have new updates in the next 4 weeks... she is suppose to be running this coming week and the body is suppose to be done by memorial day... I sure hope so,,,
not a lot, but it is a start...
picked up seats... don't know what they are out of but at FREE!!! who cares.... lumbar support and integrated seat belts..
now to figure out how to mount them..
well the first seats didn't fit at all... so I just picked up a new seat, test fitted, and it will work great... came out of a mid 80's Ch*vy but don't think it is original... split bench with center armrest and electric lumbar support... and a good price, not quite free but only $40... it's nice to know people...
Those seats look nice for free. Got to like the wide radious fenders on the 4x4s. Thats how it gets done a little at a time.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
1965 F100 4x4x352
1998 F150 4x4x4.6
a little a day.....
Well, after about 2 hours of wrestling with the seats... they will NOT work..
they are not too tall and I can do the mounting so I fit under the wheel just fine, buuuuuuut, the seat back is too thick and will not go back far enough to get me away from the wheel..
even after trying it all, I could drive it with them but would not be comfortable for any distance. with all this said, they will go back where they came from and I will be on the look again..... just a minor setback... I still have time...
Love the build
- slickmainer
so the buckets didn't fit or the chevy bench or both?
--Gregg--
you can't get there from here
the buckets didn't fit so when I deleted my photobucket pic, it disappeared from here also.. I posted up the pic of the bench I will be using and the pics are of it in the Slick... sorry for the confusion Gregg..
- slickmainer
makes
--Gregg--
Anthony, My 95 F-350 has a split bench seat with a fold down center in it. This seat has a thin back and should be easy to remove the headrest from it. This seat all mounts on one frame so it should be easy to make it mount in your truck.
I am thinking about changing the seat in my 63 to one of these. The seat inmy 63 is comfortable but the back is too thick and pushes me to far forward.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
I used a 94 seat in my 67. Should be the same for our Slicks.
http://s63.photobucket.com/albums/h142/ ... 20Install/
- bobenhotep
It is good to see someone else with a 300! Keep up the good work.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
just a little bit of progress...
Great job anthony ! Once you get it running, YOU'RE keep the truck going for sure. tony
tailgate and grill pics!!!
as I got it...
cleaned up.. found only one hole from rust.. just to the right of the handle
in primer...
grill as it turned out..
I guess it was cleaned with A/C coil cleaner before he shipped it to me..
and as I picked it up today!! WOOHOO!!! I Likey!!
powder coated chrome
progress is slow but it is moving along...
as I got it...
in primer...
- jkimbrel65
That looks awsome Athony!!
Mike
Mike
I tried being normal once...
That looks awesome. I used powder coated chrome on my oil pan just for grins. I thought it would be a great solution for a grill too. Thanks for proving it! Mine's steel so I plan to do the same with it.
