Started by going to Pull-a-Part in Nashville. Found a spare tire "reel" in an S-10 that had the bed removed. Then I built a crossmember for it.
After removing original spare mounting bar, I anstalled this one in between the rails.
Drilled below the tailgate with a 5/8" lining up the hole with the reel.
Made a shaft that will use my lug wrench to turn it.
And . . . . it's mounted.
