65 4x4 on eBay
Shillinghill
65 4x4 on eBay
Hello Everyone, I saw a nice looking 65 F250 4x4 on eBay I would like to hear your comments about this truck. I've been looking for one of these, too bad it's in CA not PA. Thanks!
- jkimbrel65
Shillinghill
Re: 65 4x4 on eBay
Sorry, I forgot the link.
http://cgi.ebay.com/ebaymotors/1965-For ... 732wt_1165
Re: 65 4x4 on eBay
It is a factory 4x4 with the 3000 lb front axle. The price is not yet too high, but it hasn't yet met the reserve. I like the flare side and the factory grille guard. Send him a question to get his number and call him then buy it and drive it home!
Pat
Pat
Re: 65 4x4 on eBay
Hi Im not sure what you are thinking. If you are thinking of driving it back to Pa from CA I would count on a long slow gas sucking drive. The rear gearing for these 3/4 ton 4wds seems to be 4:56. You might ask Iceman what it cost him in gas to go from Alaska to Arizona. Im not sure the gearing in his 4wd rig but if he hasnt changed it it should be that same gearing. Otherwise it looks to be in just about the same shape as most of the 4wd rigs of this era seem to be. Worked hard till they cant work anymore then cast aside. On second thought what I just said probably holds true for the private sector while it was being used by the Army it probably was regulaly maintained so that probably is a plus for this truck.The good is that if it stayed a California truck the body rust wise will or should still be in pretty good shape which if you restore it will save alot of money in the long run. These trucks look sharp when they are restored and are somewhat rare. There are those that say they wont be worth much but I disagree because they were somewhat a rare option as the years go by the early Ford factory 4wd will become harder and harder to obtain which means the price will be going up. Personally Ive always liked the looks of them so thats why Im saving 2 of them. I
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
1965 F100 4x4x352
1998 F150 4x4x4.6
Re: 65 4x4 on eBay
From my recent observations, price is in the same range as the standard 2wd. There was a better looking truck in Reno area for 2800, but it sold if i'm not mistaken. There are significant differences between 65 and 66 in the suspension, on the front. There is a 66 short wide bed in the Reno area for 4200 asking price. Also a rough long bed 66 ford 1000. Idid not need temptation , so I did not stop and look at either of these trucks. From my trip to retrieve my 66, I will say it's cheaper to ship than drive. You also take a risk of breakdown. As to value, my guess would be between 2 to 3K max. Search oregon and washington craigslists for fair values on 4x4 trucks. Lots show up in those areas. I paid 4250 for my 66 shotbed, but got lots of goodies on the truck.Air condtioning, ididit column, fancy seats with built in shoulder belts, lock box consul, rebuilt 390 with rpm intake, march pulleys, beautifull headers, to big a cametc., larger wheels and tires fairly new, custom gauges and dash, new tail light doors and lenses, bushing and axle rubbers replaced, custom headlights, and had a stereo installed,although someone damaged that by trying to steal it. Truck also has a set of Lmanns type valve covers. This should give you an idea of a value.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
Re: 65 4x4 on eBay
mine is 4.56
i have no desire to ever change it, nor do i care about the slightly less mpg.
it goes 75 on the highway with no problems and in low range 4x4 will go thru just about anything.
it does what a f250 4x4 is supposed to do.
i pulled it with the crewcab about 50% of my trip down here so i cant give an accurate figure on cost.
i would drive it anywhere and its value to me far exceeds anything new.
there are a couple i have seen on cl in nearby areas that are reasonably priced and would buy if i had the $,
Re: 65 4x4 on eBay
Hey Ice quick question for you. Are ;you running larger than stock tires on your 4x4 with the 4.56. I had a 292 in my 63 before I shut it down and tore it apart. I never had a tach on it but I recall that motor sounded like it was screaming at about 60. It had one size smaller than 7.50 16s on it. But yes it could haul and pull just about anything. When it comes back on the road in a year or two it will have and upstroked 360 for power and Im planning on at least 7.50 x16s if not larger diameter thats why Im curious what size tire you are running. I am however still thinking about getting a front and rear axle out of later model 4x4 with a little higher gearing around about 4.10 or a 3.70.
Edit: Ice in my 65 4x4 with a 352 Im running tires comparable to 7.50x16 and a 3.50 gear. Now that truck will run along at 60-70 all day long. I do not have a tach on it so I cant honestly say what rpm the motor is rotating at but it certainly does not sound like it is struggeling to run at those speeds. Im going to be checking miles per gallon this summer as I did not do it last year. I dont worry about mpg as these are hobby trucks but if I ever needed to drive long distance on a budget I would at least be wondering about it.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Re: 65 4x4 on eBay
i have a fresh 292 , front tires are 255-85-16 rears are 33-12-16.5 (same circumference so no diff issues.)
70 mph is 3400 rpm
70 mph is 3400 rpm
Re: 65 4x4 on eBay
Thanks I had yet to crunched the numbers in a tire size + working gear calculator. So I was unsure of a working gear using 33 tires. Sounds like its very doable if I leave the 4.56s in and dont change out the front and rear axles. Do you have those tires mounted on something like the old innie 8 lugs thats what I will be using for wheels on the 63.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Re: 65 4x4 on eBay
front tires on stock 8 lug innys
rears on 9" wide 8 lug innys
Re: 65 4x4 on eBay
Did you come up with those rears pretty easy. Ive been keeping my eye out for 4 of the ones you have on the rear I have yet to see even one around here. It was hard enough to finally come up with 4 of the standard 8 lug innies.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Re: 65 4x4 on eBay
i had several of them and the 16" innys too, brought what i had room for the rest are back up in Alaska.
possibly i could have them shipped after all the snow is gone
theres some in the for sale section too.
Shillinghill
Re: 65 4x4 on eBay
Thanks for your comments everyone, I think I'll pass this one up and keep looking.
Re: 65 4x4 on eBay
$3,400.00 right now. Im guessing his reserve is closer to $4,000-$5,000.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
