66 shutters and shakes pretty hard
BiffWilley
Post by BiffWilley »
Hey all! I've been driving my 66 pretty much everyday with no issues! The ol girl turns over and runs like a champ every morning!
Recently I've noticed that she shutters and shakes pretty aggressively when i hit around 35-40 mph. She has new tires that are balanced so I don't believe thats it. If I accelerate through or let off she immediately stops the shutter.
I'm thinking its my drive shaft/ujoint area. wondering if anyone has had this issue or could aim me in a good direction of troubleshooting.
I know my front cab mounts need replaced, but the shutter sounds and feels like its in the area where the two drive shafts meet right under the seat.
Thanks so much in advance for the help and advice!
Cheers,
Biff
Re: 66 shutters and shakes pretty hard
Carrier bearing ?
Limestone66
Post by Limestone66 »
Check the front end for any loose parts, kingpins, pivot point bushings, drag link, broken or worn front shocks, radius arm bushings or anything that would contribute to its mysterious condition. Check for play on vital steering parts as this could also cause that kind of problem. :2cents:
Long live the 352
........Ron..........
1966 Ford F250 Custom Cab {Longbox}
1996 Toyota Camry {Wifes ride}
1940 Harley Davidson knucklehead {Retired in 2006, gave to one of my sons in 2010}
1975 Harley Davidson XLH {Groundpounder}
2005 Harley Davidson Deluxe {Nostalgia} Almost home 'girl'
In memory of Donald G. Roswell- My freind and 'brother'.
BiffWilley
Thanks guys! I will definitely check into those. Who knows where those are as far as condition.
Cheers,
Biff
jwh f-100
Post by jwh f-100 »
Here do you feel it most? At the steering wheel or at the seat?? Many times (but I wont say all times) if it is a front end issue you feel it in the steering wheel and If you feel it in the seat or even the cab it is a driveline issue....
Jason
Beer will change the world.
I don't know how but it will.
Post by Gritsngumbo »
I had a similar issue. After replacing the U-joints and various tweaks without success, I took it to my mechanic friend. Turns out I had apparently failed to properly tighten the lug nuts on the left front, and they had wallowed out and that was causing the vibration and noise that I thought was coming from underneath the truck. Didn't really notice anything in the steering.
BiffWilley
after talking to some more people here at work, I'm leaning more towards the carrier bearing. I don't feel it much in the steering and in my wind imaginative head it seems like its a drive shaft deal.
Thanks for all the input guys. I'll check tonight and let you know what I find!
Cheers,
Biff
R Pope
Post by R Pope »
I'd bet its the center bearing rubber mount. The good news is, the bearing and mount is the same piece up into the late '70's or even later, so they are easily available.
SomeNewGuy
Malaysia
Post by SomeNewGuy »
Any solution found? I have been driving my 66 for the last three weeks and it started the same issue. Mine feels more like a very strong vibration almost like driving over rumble strips on both sides at both times. I found my differential fluid was a little low, and topped that off. Thinking now it might be carrier bearing even though it looks good.
Let me know if you found out what your issue was.
Before it started doing that i was hearing a sound that sounded like something rolling around in the bed of the truck, but there was nothing back there to roll around.
If there was anything else I could try, I would, but for now I GIVE UP!
BiffWilley
I'm thinking its the center bearing. I haven't had a chance to get out and check it, but it is VERY VERY similar to what you are describing aswell.
I hope to at the very least get a peak at it this weekend. I'll be sure to let you know what I come up with
Cheers,
Biff
totten
Post by totten »
X2 on the lug nuts backing off, ck carrier bearing housing rubber is bad.
