300 L-6 temp sending unit and aod tv cable question
ford6t5
Netherlands
Post by ford6t5 »
hey guys
i'm looking for the temp sending units location and i found a plugged hole above the starter. is that the temp sending location? i wanted to order a unit but there are three sizes. are they manufacturing year specific? where do i find what i need?
i also saw that the last bolt from the inlet mani (firewallside) is missing. could there be a reason for it?
also do i need a tv cable for an aod trans. i have the stock carb. is there a specific one that i need?
hope you can help me
any info iss much apreciated
thanks
Re: 300 L-6 temp sending unit and aod tv cable question
temp sender on 6 240\300 is on pass side below intake near firewall.
i think its 1\4 npt
sorry cant help with aod
aarons428
Germany
Post by aarons428 »
The aod cable you need is from Lokar don't settle for the cheaper ones or you will be doing it again.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
ford6t5
Netherlands
Post by ford6t5 »
thanks guys..
so 1/4 npt shoud it be?
any thoughts wy the last bolt is missing? the engine has a new head by the previous owner..
see ya
twan
last bolt was not tightened enough, probably got loose and fell out
.i have seen it before
cooter
Post by cooter »
be careful of the aod cable, if the adjustment is out then it will not shift right and kill the clutches.
ford6t5
Netherlands
Post by ford6t5 »
thanks everyone!!
see ya
twan
