I started with the caliper mount. The calipers are 71-76 Impala and should stop an F100 just fine.
See that steering stop below? It will need to be adjusted later or the caliper will contact the I-beam.
It says in the instructions to grind this bump, you will need to pretty much remove it to mount the caliper.
This is what is should look like after you grind it
ALMOST DONE....unless you have American Racing Wheels like I do
The AR wheels are not hub centric like a stock wheel, and even worse the centers are smaller than a stock rim, causing them to not sit flat on the rotor. So I had to grind a taper into the rotor so the American Racing Wheels would sit flat on the rotor. It took about an hour per rotor but my wheels now fit. A metal lathe probably would've worked great, if I had one.
Passenger side. I connected the new flexible brake lines to the stock hard brake lines, leaving the original routing. I had to "adjust" the Speedway brake line bracket with a hammer until it was flat, then mounted it about 1/2 off the frame with a spacer so the retaining clip can be accessed.
I bled the brakes with the stock "fruit jar" master cylinder still in place, it will not work with these discs, it does not push enough fluid, the brakes are spongy. I am going to put a correct manual disc drum master cylinder with new lines on next week, but until then I can at least move the truck in and out of the garage under its own power.
The installation was pretty easy and the price was great, and I'm sure with the correct master cylinder this setup will stop great.
