swap?
shortbox65
swap?
hey how is everybody?, well I was wondering on how complex, or if it's a dumb idea but has anyone swaped a slick to a '97 and newer f150? thanks
Well the wheel base would be different (longer) so you would have to shorten the frame.
The width would be different and you would have to fabricate some cab and bed mounts.
The engines sit farther bask in mewer trucks so the firewall would have to move or you would have to move the engine.
SO in one word...VERY.
- Johnny Canuck
- FORDBOYpete
My SWB 66 Styleside sits on a 79 F-150 Trailer Special chassis for the reasons JC alludes to.
It's a virtual Bolt up deal with a minimum of tweaking & fudging. The engine bays are virtually the same, everything just bolts together.
The rear frame or CA Area is what's problematic as it is both 3" wider & 2" longer so there is a little creative fudging & repositioning & redrilling there.
But for my
I 'll do whatever it takes because I like the Newer technology & options, the rear mounted tank, the greater rear axle track width, the saginaw P/S those huge Trailer Special PDBs et al
I will add this is NOT The Case With the LWB TRUCKS
FBp
But for my
FBp
Change is the Only Constant
shortbox65
re:swap
thanks for all the replys, I was wondering because I have a '65 short step side and was wanting to do away with the twin-I-beams and go to a traditional A frame style with out going towards the crown vic swap.
thanks again
thanks again
wrong thread
- ezernut9mm
what's wrong with the twin I? if your wanting more cornering stability the later ball joint style i beams can be made to handle quite well.
in fact when the first generation ford lightning pickups came out in 1993 they held the skid pad better than the mustang, camaro and were equal to the vette. not too shabby for a 4400 lb pickup.
you might do some measuring and see if the slick body will mount on the 92 to 96 frame.
shortbox65
swap?
there is nothing wrong with the twin I beam its a great truck suspension, but it is a little hard getting it raked without affecting alignment, I heard both sides of the Dream beams and just don't know which direction to go.
I would like to get a little lower and add power disc brakes, steering, and bigger motor, and have something similar to the white slick on pinks.
- Alan Mclennan
Hey Shorty,I have dream beams with 79 stubs and discs the springs were shortened 1" and with 17" rims with 255/60 tyres LENORE sits 37" to the top of the guards,she handles very well but could do with sway bars which may be my next post!
Alan,
Alan,
For some time now, I have been noticing wrecked Explorers for sale cheap. With gas being as is, I thought about droping one of our bodies on one of these frames. Anyone know how well the wheels would line up with existing frames and bodies? I also like the explorer seats, and have both mountainer and Explorer seat in my cabs. These tend to set to high, and the back need to be dismantled and upper fame heated and bent to give better fit.
- Johnny Canuck
Rich if you are talking about Explorers with a six, I would leave that one. I test drove one of those with a six and man, it felt like you had to get one leg out and Flintstone it to pass a car. Actually, test driving an Explorer six was the reason I bought a Jeep Grand Cherokee. The Jeep was like a hotrod with a six, with a V8 it was like a rocket compared to an Exploder.
