Fan Shroud 262-6
Texas Monty
Fan Shroud 262-6
Post by Texas Monty »
I have been informed that the fan shroud for 1967-1976 353/360/390s will work on my engine. Direct Ford Parts say they can't promise me that, but I have been assured by some...
The radiators 'look' the same.
"Linda Lou" 64-F100
i would then guess you have a big radiator for your 6.
i have a 223 6 radiator from a big truck (61 f500) that looks close to the FE size and has a shroud.
the 223 in a swb 63 i have is very small in comparison.
measure the radiator you have, and if possible the FE radiator or the shroud and you will know.
Macon ACE
Post by Macon ACE »
I have a '64 292 and installed the shroud you mention. It bolted right up the the rad - BUT the shape was a bit off. I had to cut the bottom off or the fan would hit.
Not a problem for me since all I really wanted was to have a little protection from the fan.
64 Ford F100 Flareside
68 Ford XL Convertible
87 Ford Thunderbird Turbo Coupe
94 Ford Mustang GT Convertible
02 Ford Mustang GT
18 Ford F150 XLT
