64 4x4 steering
napass2004
64 4x4 steering
Post by napass2004 »
i've seen a lot of different ideas on power steering for the 61-65 4x4 power steering setup. I want to know if anybody has done it successfully and it works as a daily driver, I'm looking to do it for a reasonable price without having to hack up the whole frame. Pics would be nice and very helpful. Thank you Kyle
Hawkrod
Post by Hawkrod »
Well, since you asked.... I did not do a 4X4 but I did do a 61 straight axle and I used the 77-79 F250 integral PS box. I made a bracket to adapt it to the frame up front but I did have to "clearance" the front crossmember. It did work sweet though! Hawkrod
napass2004
thanks but i dont know if thats the same i know the 4x4 frame is a lot different than the 2wd frame. do u have a pic of it?
pipedobber
Post by pipedobber »
I installed a 76 ps box on a 66 4x4 frame with the coil spring front axle. Hardest part was laying out the bolt pattern. I cut the holes in the frame and used 1/2 inch sch 80 pipe to go all the way through the frame and welded them in. This allowed me to pull from both pieces of the frame and strengthen it. I took the rag joint a part, shortened the steering shaft, and welded it back together. Drove it every day no problems. Chris
napass2004
i think that the 66 w the coil springs were also different i know 61-65 4x4 are basically the same but i think the 66 had the steering boxy in front of the axle werent they?
66f100 4x4 has coil spring front end, ps box is from 77-79 big bronco or 73-79 f100 4x4.
robert porterfield
Post by robert porterfield »
napass like ice says 66 f100 4x4 is a coil spring truck if i read your origanal post right your asking about p/s install on a '64 4x4 ? if so i'm still gathering parts to work thru mine as i asked about that same thing awile ago ice showed me a pic from his album that helped me w/ some of the parts needed i belive the ram assist steering from the "old f250 hi-boys" is the basis for this coversion my set-up issn't complete yet as i have a 300-6 motor and mounting the pump on the engine interfere's with inner fender so i am waiting till i have time to break truck down and mod that to get pump on and install rest of parts............. hope this helps p/s iceman can you post that pic of that chassis w/ hyd drag link installed?
lifes hard wear helmet!
66 f100 4x4
[albumimg]3778[/albumimg]
66 f350, same as 61-65 4x4 ,with later disc brake d44 front end and ram type ps
[albumimg]3007[/albumimg]
[albumimg]3008[/albumimg]
Hawkrod
Post by Hawkrod »
napass2004 wrote:thanks but i dont know if thats the same i know the 4x4 frame is a lot different than the 2wd frame. do u have a pic of it?
Actually the 4X4 frame and the 61-64 2WD frame are almost the same which is why I posted. I have had both and there are differences but the similarity of a straight axle 2WD frame and a 4X4 frame are amazing which is what gave me the idea for using the 4X4 steering box in the first place. I have had both a 61 2WD and a 61 4X4 (sold the 4X4 chassis to someone here on the forum because he was converting his 2WD). Hawkrod
