colum shift problems
- 1961 slickwilly
I finally got to drive my uni and went to shift from first to second then it just wouldn't shift so far first and reverse is all i can get it to do. Any help anyone?
- MattsIASlickShop
Check your cab mounts. They could be rotted away and the cab has sank to the frame.
Or, it could be the shifter rods are out of adjustment.
Or the shifter is loose and the selector is stuck between the two arms on the column under the hood. This is actually my first choice. while parked on a flat surface with the engine shut down, reach in and try to line up the two shifter arms so the selector arm is in neutral position.
These are all guesses to what your problem really is.
- 66fordtrucknut
- 6166 Junkyard Dog
Time after Time see column tore apart with major probelms due to front cab mounts ,, rag joint keeps tearing up parts or hard steering and especially on 65-79 trucks will tear the shaft or or bottom bearing and regardless what has been said before its important to have that lower bearing in it 65-76 uses metal bearing,, 77-79 uses the plastic bearing....
Kathy
Now Cooper will try his best
- punkrock gearhead
itsmywifestruck
Make sure your 2-3 shift rod isn't in a bind. Put the truck in neutral, block the wheels, and get under the truck and try to move both shift links on the transmission and make sure they work properly. Sometimes the mechanism inside the column is just jacked, and you just have to go floor shift.
ROb
ROb
Buzzin Half Dozen
special emergency tool
While cab mounts are a problem there are some lessons I have learned over the years from my dad. This won’t fix the problem but will get you out of a jam when you’re stuck in traffic or away from home.
The rods get jammed for various reasons. And you can be in more than one gear at once (an older guy at work told me that when he was in high-school in the 50s, 3 speeds were much more common in automobiles. A common “prank” was to open someone’s hood and push both shifter arms down, and then close the hood. The driver would be stuck).
This happens accidentally as well. My father made a hook (a rod about 14 inches long hooked on both ends). This allowed him (now me) to unbind the linkages without crawling underneath the truck. About once a year I get stuck, so I shut the engine off, take the hood and pull one linkage UP, then re-check the shifter. If that didn’t work I pull the other one UP and re check…sometimes one need pushed down as well.
These newer transmissions should not shift into both gears at the same time, and I'm not sure the ones in the fifties would. If those would, then the transmission has a problem. First thing Willy needs to do, it atdjust the shifter linkage. this is done by putting the truck in nuetral, then take both rods loose at the transmission. You need a round rod about 5/16 inch in diameter, ( may be different size don't remmember for sure) slide it thru the square sheet metal below the shift rods on the column housing and thru the holes on the shift arms. this will align the shift arms soyou can adjust the linkage on the rods to the nuetral position of the transmission arms. Before you adjust the linkage make sure you have the column in the truck right. There is a flat spot on the side of the column that faces right towards the brake pedal for clearance for your foot when braking. This needs to be adjusted before you adjust linkage. Might as well adjust the gap on the steering wheel and column shifter while your at it. Make sure you have all the correct washers on the shift linkage rods when attached. These need to be there for a tight shifting setup and other reasons, the hairpin clips are a bear to get on aand off with everything in place. the two washers on the rubber grommet ore extremely thin and only the orginal washer are that thin, so it's hard to find replacements for those. The lower washers are also thin and have a spring washer also, but you can do without the spring washer, and use thicker washers there. The cab sag doesn't affect the earlier shifting as bad as the 65-6 because of the integral calumn shaft/ There is a rubber bushing at the bottom of the column that needs to be there as it keeps out dirt. What is nice on the older models is the grease zerk where you can keep the column shifter arems grease which helps keep out dirt and water, as does the rubberbushing at the bottom of the column shroud. Cab rock and sag will affect the clutch linkage badly and shift linkag some on the 61 thru 64, as will motot mounts. Worn or bad engine mounts will let the motor and trans moove all over with origianl style engines and mounts. Both upper and lower should be raplaced if bad. Remmember the 61/4 trucks did not have transmission mount to hold the transmission steady. Even when worn the later trucks transmissions were not as likely to move around as much as the earlier trucks.
Hope this helps
Hope this helps
also have to remember unless you have done all the above and new parts installed that folks have hard shifted these for years, but they are not like a top loader where you can be real agressive in the shifts without wearing bushings or even bending the rods.
i have seen lots of messed up column linkage , and instead of trying to repair properly a floor shift is installed.
- punkrock gearhead
cavinandpavin
HELP!!!! I went for a road test today after puttin the ol girl on insurance and a current tag... but i couldnt go over 25mph cuz i couldnt get into 2nd muchless third, seems to be the same problem as the original poster. i have checked the following. i can put it in 2nd and 3rd from under the hood noproblem and the shifter collar(i guess thats what its called) moves freely in a rotation around the steering shaft BUT it will not i repeat will not go up and down around the steering shaft, i soaked it with some lube and am letting it set for a while, the last time the truck was driven it have no problems going into gear. as far as i can tell my cab mounts are good the rag joint(i assume is inbetween the steering shaft and the gear box is flat doesnt have any signs of stress on it and i loosened the sheering collumn at the bottom and it had no play. alot of what was posted before kinda looks like latin, so i guess i am asking what would hold the shifter collar thing from moving up and down around the steering shaft. thanks in advance, i would like to take her in to town saturday mornin, and i do not want to put in a floor shifter. thanks in advance!
No, its not a windsor or a cleveland, its a three fifty TWO!
cavinandpavin
right now i am mad... pevved off and all that so i am thinkin hard about goin and pickin up one of these at the local 24 hour parts house. http://shop.advanceautoparts.com/webapp ... RP2060____
should i not do it, or go for it??
