Pulling the engine - best place to connect the chain
BarnieTrk
Post by BarnieTrk »
charliemccraney wrote:A 5/16 bolt tightened to 60 inch pounds, about appropriate for a carburetor, has a clamp force of about 958lbs. If you can properly torque the bolt in an aluminum manifold without it stripping, then that single bolt can support the entire engine. I do not recommend that one bolt be used with a lift plate because the forces applied to a single bolt by the lift plate will be potentially disastrous; it will in effect be prying the head of the bolt off rather than pulling straight up and applying an even load. At 12 ftlbs, which is a common torque for a 5/16 bolt, a clamp force of about 2300lbs is applied.
I understand that it's difficult to grasp just by looking at that little bolt but physics does not lie.
I really don't want to argue the point. And, I agree, physics does not lie. However, we must ensure we are comparing apples to apples.
Just as not all 5/16" studs are created equal; some are made from Grade 2 stock and those made from Grade 8 stock which present different stud strength ratings. A similar arguement can be posted regarding the differences in the clamping forces between comparable bolts versus studs.
Considering your posted 5/16" bolt specification of 2300lbs, why shouldn't a fella hook not one, but TWO engines on ONE bolt (as I suspect 2 engines would not weigh a total of 2300lbs)...? Why not, because, as you point out, there are OTHER FACTORS involved when lifting an engine that the "bolt shear strength chart" doesn't consider. Such as side loads, loading to the bolt head, jerking loads, and as mentioned earlier, there may likely be corrosion to the bolt or the threads in which the bolt is in, which would lessen its clamping / holding capacity as well; none of which are considered on the chart.
This discussion reminds me of the advertised strength of chains....
Anyone ever break a chain while trying to move objects that weighed much less than what the chain was rated for? Such a situation brings us back to the OTHER FACTORS INVOLVED that are not considered when only the rating of the chain is considered.
BarnieTrk
charliemccraney
Post by charliemccraney »
If the lifting apparatus is designed appropriately, there is no reason a single bolt could not be used to lift two engines. Using a lift plate with one bolt for two engines would be like using a hammer to torque a lug nut - it ain't gonna happen, it's the wrong tool. I wouldn't call that an other factor. I'd call it improper use, and to be less pc, stupid. Lift plates are not designed to function in that way. For the sake of the lift plate, the grade of the bolt is of little concern. It's the reason I also mentioned the 958 lbs of force for a 60inlbs torque. A 60inlbs torque is not going to hurt a grade 2 bolt. If 60 inlbs does not strip the threads, and it should not for a good aluminum or iron manifold, then it stands to reason that those threads can support at least 958lbs each. Obviously, if the threads look terrible, it may not be a good idea - just as you wouldn't use a rounded box end wrench to remove bolts, don't use a lift plate if there is an obvious problem that will result in the unsafe use of that lift plate. Three or four (depending on just which carburetor pattern is used) grade 2 bolts will do just fine. With three or four bolts, the load will be distributed evenly and safely to do the job whether they are grade 2 or extra high strength ARP types of bolts.
Those figures have nothing to do with the yield of the fastener. That's just the approximate force applied for a given torque and diameter. The yield will be greater than that.
If you use the right tool in the right way, a lift plate and three or four bolts, it will work fine. There are no other factors when a tool is used as designed. So use a lift plate as designed and everything will be great!
bunchoftrucks
Post by bunchoftrucks »
One thing that I see here is that nobody seems to mention the fact that the all the bolts out there are NOT created equally. Last year a nationaly recognized testing lab (I don't remember which lab the article I read was in ENR I think) took the question of Chinese steel and fasteners being inferior and out of spec to the lab. They purchased on the open market 80 tons of various types of steel( I beams,tubing, channel and flat stock) from the ROC. Over 60% of the steel products failed to reach the design/tensile strength that they were advertised to meet. If you have noticed that almost every fastener is now made overseas and after reading that article I am very careful where I get my bolts and nuts. I have used a lift plate and will continue to as long as 1. I know where the bolts came from . 2. the threads in the intake are sound. Also as far as chain goes you get what you pay for i.e. if you by it from China you get what you pay for cause they know what they can get away with and do. Be smart, buy good, buy American and be safe.
64 F-250 4x4 391 FT
66 F-100 4x4 352 FE
64 shortie 302/AOD
LM14
Post by LM14 »
I've used lifting plates for 38 years without a single failure. Did my first engine swap with one and almost every one since. Home made and store bought. We just leave one hooked to every spare engine we have. I trust my dry sump, Yates headed, big buck dirt late model engines with an iron block to one without a second thought, price one of those lately?
I will continue to use lifting plates and I would guess I change engines more than most of you. Sometimes every week if we're experimenting with cams or motor locations. We also have 2 cars to keep fresh engines in, we change a lot.
The plate also won't scratch your fresh engine paint like a chain for those making things look nice.
Use the plate and don't worry.
