This bracket is needed for small blocks etc that DOESN'T have the tapped hole in the block for the pivot ball, I have one on my 351W in my 1965, I need the same thing for my 302 / 5.0, I got one out of the junk yard off a 1964, it will NOT work, the following is some rough measurements of the one off my 351, I have NO idea WHAT year these brackets actually came on
Center to Center of the mounting holes ( these mount to the bellhousing with/to engine bolts ) is somewhere from 3.70 to 3.75 one to the other, center to center.
From the inside of the bracket which I call the surface which contacts the bell housing at the mounting bolt location to the center of the pivot bal is about 2.550 or about ( 2 1/2 inches )
From the center of the bottom mounting hole to the center of the pivot bracket is about .600 or close to 1/8 past 1/2
This bracket has what I call a stiffener bend on some of the sides, it is a short bend at the sides.
I need this bracket ASAP, I swapped a OLD 302 that has the drilled/tapped hole in the block for the pivot ball with a 1989 5.0 that doesn't have it, my truck is tied up in a garage waiting on this
thanks
putting 5.0 in 65, need pivot ball bracket ( @ engine )
Griffin GA 1965 F100
Have 3, one daily driver others in different state of repair/disrepair
- FORDMANLCRACKEL
I made mine while i had the bellhousing bolted to the engine on the test stand. I dont have any measurements.
Lonnie
Lonnie
Thanks for the photo
Thats a option problem is the truck is held hostage in a shop, need a bolt on
too bad you didn't make a print of your setup for others to follow
