'57 fairlane y block into a '64 slick
so ive found a good replacment motor for my 64 slicks y block that blew up. i found a good running 292 y block out of a fairlane. its a '57 so it will have the better heads. do i have to worry about any clearance issues? or any other problems other then switching out the engine mounts? thanks
'64 ford bbw custom cab short styleside bed
'32 ford 5 window body
'28 ford roadster pickup
'04 ford f150 crew cab short bed
You have to switch oil pan with pickup tube, passenger car has front sump and in truck is rear sump, and timing cover to get the front motor mount there. Also water pump has thicker shaft that is in passenger car. And oil dipstick is in different location.
Tero from Finland
61 F-100 Unibody SWB
61 F-600
56 Country Sedan
55 F-620
52 Mercury Monterey 4D
http://www.dlc.fi/~teros
http://www.y-block.info
http://www.hollowheads.net
http://www.fordnationals.net
61 F-600
56 Country Sedan
55 F-620
