Speedometer Cable
Shawn F.
Speedometer Cable
Post by Shawn F. »
I need to fix my 66 F100 speedo cable ASAP. I have a 351W and C4 tranny in it now but need to know where to get the exact cable I need? I see some for AOD's and 3 speeds but not sure what to do about the original gauge to the C4 auto tranny. I need the cable, sleeve and ends. I want to just get the correct one, screw the gauge side on, bolt the other end to the tranny and go.
Local auto parts store sold me one but it was just an actual cable... No ends, no sleeve, nothing.
Thanks for any info!
Southern64
Post by Southern64 »
In need of the same thing, put a c4 in my 64 and need to hook up asap. Somebody please help...
Long63
Post by Long63 »
Have you tried Dennis Carpenter north of Charlotte or Carolina Classics in Durham NC?
For that matter, I would think a Mustang Store since they came with C4 in the 60s and 70s.
Gary Seymour
Post by Gary Seymour »
I am using a 351C / C6 and have noticed that the original cable will fit the C6 Trans (from an '85 E150 Van). What I do not have is the cable drive gear at the trans, and do not know which one to get for a 3:25 gear and the C6. Apparently Ford's spedo cables didn't change over the years??
Fordman
Post by Fordman »
i see mention in the first post of a cable that goes into the transmission. which i have seen before. i have seen these cables on ebay and at many of the vendors. when oredering from anyone just make sure to ask if the cable goes into the transmission and has the gear holder made onto the transmission. same as the second post i would assume. for the third post it sounds liek you just need the correct gear for your cable. i have seen those in the vendors catalog also. you will have to calculate rear end ratio and tire size to get the correct number of teeth for the new gear.
the gears did not change much, colors and amount of teeth is how they are sold.
cables from the mid 70s up will not screw into your slick speedometer.
if you take the time to look you can find complete new replacement cables not just the inner piece
i have got them thru my auto parts store before.
Gears are available too. LMC and some of the other places i think.
07mike
Post by 07mike »
I bought mine from NAPA. I ran a wire from speedo to trans to get the length then looked in their paper catalog for the correct ends, then checked for the lenght I needed. Part was in stock at the local wharehouse.
Shawn F.
Post by Shawn F. »
Fordman, mine now that I think of it, may not be the one that goes INSIDE the tranny. I will have to confirm this later tomorrow or day after. I just really need to get something that is done and goes right on. I am tired of messing with trying different gears and crappy cables from auto parts stores that dont work and not knowing how fast I am going or the mileage on my motor.
bluebolt
Gears
Post by bluebolt »
Gears are available at your Ford dealer.
Manual Transmissions:
16-teeth-wine (C0DZ-A)
17-teeth-white (C3DZ-C)
18-teeth-yellow (C0DD-B)
19-teeth-pink (C0DZ-B)
20-teeth-black (C1DZ-A)
21-teeth-red (C4OZ-A)
Auto Transmissions:
16-teeth-blue (D0AZ-A)
17-teeth-green (C7SZ-A)
18-teeth-gray (C7SZ-B)
19-teeth-tan (C7VY-A)
20-teeth-orange (C8SZ-B)
21-teeth-purple (D0OZ-B)
Shawn F.
Post by Shawn F. »
Thanks for the info! I have 3.70 gears in the truck now but plan to throw in some 3.25's that I have had sitting around for a few years. What color will I need with 3.25's and a 75 series tire on stock rims?
cdherman
Post by cdherman »
Find the rotations per mile of the tire you are looking at.
Multiply x your differental (3.25)
Multiply that x your speedometer DRIVE gear teeth (the one inside the tranny, usually 7 for truck)
That number, dividided by 1000 is the tooth count of the DRIVEN gear at the end of your speedo.
So, for instance, my tires are 7.50x15R15 which have 760 rotations per mile.
I have a 3.00 rear, so the drive shaft rotates 2280 per mile (760 x 3)
The speedo drive gear has 7 teeth (its a spiral gear, and you count the teeth by looking at it from the end -- you cannot count the teeth from the side. Look at it like a flower and count the petals. You cannot do this with the gear in the tranny)
2280 x 7 = 15960
Now divide by 1000 and you get roughly 16, for a 16 tooth DRIVEN gear.
FYI, all speedos and odometers made for the last 1/2 century or so, record 1 mile per 1000 revolutions of the speedo cable. If you can understand gearing ratios, you can calculate out the gears to get your odometer correct. If the speedo cable is rotating correctly to record one mile on the odometer per mile driven, the speedo should be correct (or its malfunctioning due to old magnets).
Hope that helps. If you find the rotations per mile of your tire, I'd be happy to run those calculations for you again, using your numbers.
1683
Planned/considered upgrades:
Shawn F.
Post by Shawn F. »
If I can figure out the rotations per mile then I will let you know. I only know my tire and wheel size and gear size... Other than that I have no clue. I'm a complete idiot when it comes to math and remembering how to calculate things like this.
cdherman
Post by cdherman »
Most manufacturers list rotations per mile with their other specs on tires. There are also calculators on the web. Just plug in the tire size (ie p235/75r15).
1683
